Creating snippets in Caddyfile inside proxy
adding resuable snippets
(logging) {
level DEBUG
format console
admin off
auto_https off
import logging
#Variables in Caddyfile
&(dweb3-api) {
(snippets) {
level DEBUG
format console
# Match requests that dont start with a name and tld (assets, subpaths, etc)
@no_domain {
path_regexp no_domain ^/([^/.]+/|[^/]+$)
# Match requests that need a trailing slash
@missingSlash {
	not path */ # Skip requests that already end with /
	not path *.* # Skip requests for files (e.g., .js, .css, etc.)
# Match requests that end with any domain in DomainEnum and do not have a trailing slash
# Redirect to ensure trailing slash
# Redirect domain requests to ensure trailing slash
handle @domainWithoutSlash {
	redir {path}/ 301
handle @no_domain {
	@has_referer header Referer http://localhost:8000/*
	handle @has_referer {
		reverse_proxy localhost:3000 {
			transport http
			method GET
			# Pass a static value indicating that we have a referer
			header_up X-Id-Name hasReferer
			# Redirect to X-Content-Path in case we don't have a domain and its the html call
			@redirect301 status 301
			handle_response @redirect301 {
				redir {rp.header.X-Content-Path} permanent
			# Reverse proxy to ipfs
			@proxy status 200
			handle_response @proxy {
				reverse_proxy {rp.header.X-Content-Location} {
					rewrite {rp.header.X-Content-Path}
					header_up Host {rp.header.X-Content-Location}
					header_up -X-Forwarded-Host
					header_up X-Id-Name {rp.header.X-Id-Name}
					header_up X-Id-Cid {rp.header.X-Id-Cid}
						dial_timeout 2s
						redir {rp.header.Location} permanent
	transport http
	method GET
	header_up X-Id-Name {http.request.uri.path.0}
	@proxy status 200
				dial_timeout 2s
:8000 {
import logging
bind 0.0.0.0
invoke dweb3-api
This part is repeated two times after two differnt conditions.
@proxy status 200
				dial_timeout 2s
I tried to make it a snippet to reuse it but Caddy throws errors. Does anyone know how to solve this issue? How to make this part reusable?
Why are you defining a snippet inside a named handler? What’s the goal? You cannot do this. Define them as regular snippets and import them. If you must use the named handler, define the snippet outside then import it.
