I am looking to create a local mirror for the APT (Debian) and RPM (Fedora) Repositories since I have quite a few Caddy Instances and it would speed up the apt update and dnf update Commands significantly.
Unfortunately, there doesn’t seem to be an easy Solution out of this
APT
It seems I could finally manage it with debmirror:
debmirror --debug --rsync-extra=none --host=dl.cloudsmith.io --root=public/caddy/stable/deb/debian --dist=any-version --section=main --arch=amd64,aarch64 --nosource --method=http --cleanup --keyring=/usr/share/keyrings/caddy-stable-archive-keyring.gpg --omit-suite-symlinks /data/debmirror/caddy
RPM
I can manage it with dnf reposync, but I need to define a Repository in /etc/yum.repos.d for each Version & Architecture that I want to download
dnf reposync --releasever=${FEDORA_RELEASE} --arch=${FEDORA_ARCH} --norepopath --repoid=copr:copr.fedorainfracloud.org:group_caddy:caddy --download-metadata --delete -p /data/dnf-reposync/caddy/fedora-${FEDORA_RELEASE}-${FEDORA_ARCH}/
Whereas with wget first of all it creates a host of sub-sub-sub-sub-directories OR I use --cut-dirs=3 but then I cannot filter using --accept-regex. Furthermore lots of Things get duplicated and a lot of <folder>.1 get created (the <folder>.1 is actually a File in most Cases, whereas <folder> is indeed a Folder).
cd /data/dnf-reposync/caddy/rpm && wget --mirror -nH --accept-regex "results\/@caddy\/caddy\/.*\/" https://download.copr.fedorainfracloud.org/results/@caddy/caddy/
[mirror@dnf-reposync rpm]$ ls -la /data/dnf-reposync/caddy/rpm/results/@caddy/caddy/fedora-43-x86_64
total 72
drwxr-xr-x 5 mirror mirror 8 Feb 27 08:12 .
drwxr-xr-x 22 mirror mirror 22 Feb 27 08:12 ..
drwxr-xr-x 2 mirror mirror 16 Feb 27 08:12 09459771-caddy
-rw-r--r-- 1 mirror mirror 8704 Feb 27 08:12 09459771-caddy.1
drwxr-xr-x 2 mirror mirror 17 Feb 27 08:12 10158389-caddy
-rw-r--r-- 1 mirror mirror 8940 Feb 27 08:12 10158389-caddy.1
drwxr-xr-x 2 mirror mirror 6 Feb 27 08:12 repodata
-rw-r--r-- 1 mirror mirror 7344 Feb 27 08:12 repodata.1
I couldn’t find any official Information on how to create such mirroring for RPM Packages.
Any help would be appreciated
