Creating and managing a PEM certificate for another container
via docker compose
ubuntu
    image: caddy:2
      - ./data/caddy/data:/data
      - ./data/caddy/config:/config
      - ./data/caddy/log:/var/log
I want to secure my coturn server, it has to run in network mode host (too many ports to map from docker) so I don’t think I can proxy it directly from my caddy container (different networks). It has two options:
cert=/etc/letsencrypt/live/turn.example.org/fullchain.pem
pkey=/etc/letsencrypt/live/turn.example.org/privkey.pem
while caddy generates these files:
coturn.domain.crt
coturn.domain.json
coturn.domain.key
docker compose for coturn
coturn:
    container_name: coturn
    image: coturn/coturn
    # ports:
      ## STUN/TURN
      #- "3478:3478"
      #- "3478:3478/udp"
      #- "3479:3479"
      #- "3479:3479/udp"
      ## STUN/TURN SSL
      #- '5349:5349'
      #- '5349:5349/udp'
      #- '5350:5350'
      #- '5350:5350/udp'
      ## Relay Ports
      #- '64000-65535:64000-65535/udp'
    network_mode: host
I understand that since I can’t proxy the coturn server directly (unless someone knows how!) I’d need to use caddy only for renewing the certificates. I’m currently using a caddyfile so If I’m not wrong I can’t use this directly (not sure).
I’d also need to create them first so to recap:
  1. create the certificates files
  2. Convert them to pem if not already in that form
  3. use caddy to keep them updated
    ??? profit.
Thanks anyone for their help
You can proxy to the host IP address.
If you’re using at least Docker v20.10.0 then you can add this to the Caddy docker-compose service to set up the hostname mapping:
    extra_hosts:
      - "host.docker.internal:host-gateway"
Then you can do reverse_proxy host.docker.internal:<port> in your Caddyfile.
It’s historically been a different solution on Linux than on Windows/Mac, so that extra_hosts line is necessary for Linux to have that hostname, since support for it was added in Merge pull request #40007 from arkodg/add-host-docker-internal · moby/moby@ca20bc4 · GitHub
