Hi @matt,
How can I apply a wildcard cert including the example.com and *.example.com?
Hi @matt,
Hi @deancn,
I split out your post into a new help topic since it’s a better fit than in the wiki.
Can you explain more what you are trying to do, and why?
Thank you so much.
Since many guys use the @ domain visit the website directly. So I feel the wildcard.example.com includes the registration domain example.com is better.
Otherwise, I will add 1 more config for the @ domain.
A wildcard for *.example.com does not cover example.com; you’d need to add both to your config.
