I have an application in a Docker Container that exposes a REST API. The app does not support SSL.
I want to use Caddy as a proxy for the app. I have a wild-card cert from DigiCert.
The following are the steps I would like to incorporate.
Receive wild-card request on Port 80 or 433; [
http://container.mysite.com] -
Redirect to base URL using SSL; [
https://mysite.com:2101/r3/]
There are over thirty different ports using Post, Get, Put and Delete
- Return response from [
Can I run Caddy as a systemd service?
