1. Output of caddy version
v2.6.2
go run . run
Windows 11 with WSL v2
Ubuntu 22.04.1 LTS
go run . run
root * ./public
I’m trying to create a middleware to learn how to extend caddy. I create the file of the plugin and put some logs to debug the stages where the plugin is passing through. When i run caddy show the log of the init, CaddyModule and New functions, but never execute the ServeHTTP function.
The middleware that i’m trying to create is a simple plugin that put the remote address on the content of the response.
These are my files:
main.go
package main
import (
caddycmd "github.com/caddyserver/caddy/v2/cmd"
// plug in Caddy modules here
_ "github.com/caddyserver/caddy/v2/modules/standard"
func main() {
caddycmd.Main()
simple_middleware.go
package main
import (
"net/http"
"github.com/caddyserver/caddy/v2"
"github.com/caddyserver/caddy/v2/modules/caddyhttp"
"go.uber.org/zap"
var k, s string
var logger *zap.Logger
func init() {
k = "simple_middleware"
s = "stage"
logger, _ = zap.NewDevelopment()
logger.Debug(k, zap.String(s, "init"))
caddy.RegisterModule(Middleware{})
type Middleware struct{}
func (Middleware) CaddyModule() caddy.ModuleInfo {
logger.Debug(k, zap.String(s, "CaddyModule"))
return caddy.ModuleInfo{
New: func() caddy.Module {
logger.Debug(k, zap.String(s, "New"))
return new(Middleware)
func (m Middleware) ServeHTTP(w http.ResponseWriter, r *http.Request, next caddyhttp.Handler) error {
w.Write([]byte(r.RemoteAddr))
logger.Debug(k, zap.String("remote addr", r.RemoteAddr))
return next.ServeHTTP(w, r)
var _ caddyhttp.MiddlewareHandler = (*Middleware)(nil)
$ go run . list-modules
2022-10-28T10:37:15.738-0300 DEBUG dupmiddleware/simple_middleware.go:18 simple_middleware {"stage": "init"}
2022-10-28T10:37:15.738-0300 DEBUG dupmiddleware/simple_middleware.go:25 simple_middleware {"stage": "CaddyModule"}
2022-10-28T10:37:15.738-0300 DEBUG dupmiddleware/simple_middleware.go:29 simple_middleware {"stage": "New"}
admin.api.load
admin.api.metrics
admin.api.pki
admin.api.reverse_proxy
caddy.adapters.caddyfile
caddy.config_loaders.http
caddy.listeners.http_redirect
caddy.listeners.tls
caddy.logging.encoders.console
caddy.logging.encoders.filter
caddy.logging.encoders.filter.cookie
caddy.logging.encoders.filter.delete
caddy.logging.encoders.filter.hash
caddy.logging.encoders.filter.ip_mask
caddy.logging.encoders.filter.query
caddy.logging.encoders.filter.regexp
caddy.logging.encoders.filter.rename
caddy.logging.encoders.filter.replace
caddy.logging.encoders.json
caddy.logging.writers.discard
caddy.logging.writers.file
caddy.logging.writers.net
caddy.logging.writers.stderr
caddy.logging.writers.stdout
caddy.storage.file_system
events
http
http.authentication.hashes.bcrypt
http.authentication.hashes.scrypt
http.authentication.providers.http_basic
http.encoders.gzip
http.encoders.zstd
http.handlers.acme_server
http.handlers.authentication
http.handlers.copy_response
http.handlers.copy_response_headers
http.handlers.encode
http.handlers.error
http.handlers.file_server
http.handlers.headers
http.handlers.map
http.handlers.metrics
http.handlers.push
http.handlers.request_body
http.handlers.reverse_proxy
http.handlers.rewrite
http.handlers.static_response
http.handlers.subroute
http.handlers.templates
http.handlers.tracing
http.handlers.vars
http.matchers.expression
http.matchers.file
http.matchers.header
http.matchers.header_regexp
http.matchers.host
http.matchers.method
http.matchers.not
http.matchers.path
http.matchers.path_regexp
http.matchers.protocol
http.matchers.query
http.matchers.remote_ip
http.matchers.vars
http.matchers.vars_regexp
http.precompressed.br
http.precompressed.gzip
http.precompressed.zstd
http.reverse_proxy.selection_policies.cookie
http.reverse_proxy.selection_policies.first
http.reverse_proxy.selection_policies.header
http.reverse_proxy.selection_policies.ip_hash
http.reverse_proxy.selection_policies.least_conn
http.reverse_proxy.selection_policies.random
http.reverse_proxy.selection_policies.random_choose
http.reverse_proxy.selection_policies.round_robin
http.reverse_proxy.selection_policies.uri_hash
http.reverse_proxy.transport.fastcgi
http.reverse_proxy.transport.http
http.reverse_proxy.upstreams.a
http.reverse_proxy.upstreams.multi
http.reverse_proxy.upstreams.srv
pki
tls
tls.certificates.automate
tls.certificates.load_files
tls.certificates.load_folders
tls.certificates.load_pem
tls.certificates.load_storage
tls.client_auth.leaf
tls.get_certificate.http
tls.get_certificate.tailscale
tls.handshake_match.remote_ip
tls.handshake_match.sni
tls.issuance.acme
tls.issuance.internal
tls.issuance.zerossl
tls.stek.distributed
tls.stek.standard
Standard modules: 99
http.handlers.simple_middleware
Non-standard modules: 1
Unknown modules: 0
$ go run . run
2022-10-28T10:39:50.894-0300 DEBUG dupmiddleware/simple_middleware.go:18 simple_middleware {"stage": "init"}
2022-10-28T10:39:50.894-0300 DEBUG dupmiddleware/simple_middleware.go:25 simple_middleware {"stage": "CaddyModule"}
2022-10-28T10:39:50.894-0300 DEBUG dupmiddleware/simple_middleware.go:29 simple_middleware {"stage": "New"}
2022/10/28 13:39:50.894 INFO using adjacent Caddyfile
2022/10/28 13:39:50.897 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2022/10/28 13:39:50.898 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0003c4a10"}
2022/10/28 13:39:50.898 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2022/10/28 13:39:50.898 INFO tls cleaning storage unit {"description": "FileStorage:/home/driveup/.local/share/caddy"}
2022/10/28 13:39:50.898 INFO tls finished cleaning storage units
2022/10/28 13:39:50.898 INFO autosaved config (load with --resume flag) {"file": "/home/driveup/.config/caddy/autosave.json"}
2022/10/28 13:39:50.898 INFO serving initial configuration
I have tried with xcaddy
, searching on google for solutions,re view the source code on github everything seems to be ok and i can’t figure out what the problem is.
