I tested nginx and caddy using the same 1200 QPS frequency, but caddy’s CPU usage was too high, about twice that of nginx (nginx is 25%, caddy is 56%). I think there may be some issues with the parameters of the caddy I configured.
v2.7.6
./caddy run --config Caddyfile
os is Linux
2 caddy server ,every is 1C1G
by docker start
level info
format json {
time_format iso8601
message_key msg
test.xxxxx.com {
tls /etc/caddy/ssl/xxx.pem /etc/caddy/ssl/xxx.key {
protocols tls1.2 tls1.3
ciphers TLS_AES_128_GCM_SHA256 TLS_CHACHA20_POLY1305_SHA256 TLS_AES_256_GCM_SHA384 TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256 TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
route /robots.txt {
header Content-Type text/plain
respond "User-agent: *\nDisallow: *" 200
request_body {
max_size 10MB
reverse_proxy /debug/pprof/* localhost:2019 {
reverse_proxy {
header_up Connection ""
to http://gateway:7000
header_up X-Forwarded-For {http.request.header.Get("X-Forwarded-For")}
keepalive_idle_conns 200
keepalive_idle_conns_per_host 10
keepalive 60s
dial_timeout 5s #
write_timeout 5s #
read_timeout 10s #
encode zstd gzip
level info
output file /var/log/caddy/access_gateway.log
format json {
time_format iso8601
message_key msg
### 5. Links to relevant resources:
<!-- Optional, but can help get us on the same page quickly. -->
[pprof profile](https://github.com/qiannianshaonian/Bifrost/blob/master/profile1)
[details="Summary"]
This text will be hidden
[/details]
According to the PPROF analysis, CPU usage is mainly concentrated on the TLS module. Is there any other way to optimize the configuration parameters of the TLS plugin?
Ah, that’s good. TLS is normally hardware accelerated these days but only for certain cipher suites. You customized your cipher suites, I’d have look at what the defaults are when I’m not mobile, but there’s a chance that the configured suites aren’t being hw accelerated. If you take out the config line that customizes the suites, does that help?
The caddyfile ciphers has been deleted.
There is no significant decrease in CPU too.
I haven’t seen any parameters that can be optimized for TLS related configurations from the caddyfile document.
Are there any other parameters that can be set? I would like to know if your stress test results are similar to mine. If so, I won’t be able to handle this issue in the short term.
High CPU usage in the TLS stack isn’t often normal. The profile screenshot you posted shows that it’s doing a lot of RSA decryption but it’s truncated after that. Do you have the full profile image (or at least the other half)?
I’m guessing lack of hardware acceleration – does your CPU support acceleration for the algorithms being used?
Thanks. I’m not sure if Go has an assembly implementation of RSA for Xeon, but then again I don’t know much about Xeon. Is it x86? I see this CL which may optimize the function but again, I’m out of my depth here. https://go-review.googlesource.com/c/go/+/481618
I don’t think it’s been merged yet. And I’m not even sure it’s the optimizations we’re looking for.
I’m not really sure what to suggest at this point other than to disable RSA cipher suites and see if that clears it up. (Hopefully clients are compatible with ECC ciphers.)
Ah, the TLS issue has been resolved. As long as the client we are testing uses TLS 1.3, this password suite issue can be resolved. However, there are other issues that arise. From the analysis of the testing data, log. zap also takes up a considerable amount of CPU. But our log level is set to error, and the amount of logs is also very small, which confuses me in terms of consumption. As shown in the following figure.
