Could not get certificate from issuer us
NOTE: I previously had successfully created and implemented a nextcloud server using the same configurations. I suspect something has happened with my token and letsencrypt.
Using Caddy to start a nextcloud server using LetsEncrypt DNS to validate my cloudflare API token that is set up for All zones - Zone:Read, DNS:Edit. I have executed a Script to create an iocage jail on FreeNAS for the latest Nextcloud 26 release, including Caddy 2.x, MariaDB 10.6/PostgreSQL 10, and Let’s Encrypt.
I enter my API token as one of the parameters in the config file, after rolling the token and when that didn’t work, recreating the token. I have restarted the Caddy service within the nextcloud jail several times.
LetsEncrypt shows that my cert is invalid due to a 405 (method not allowed)
{"level":"error","ts":1688183097.7550597,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"cjcloud.us","issuer":"acme-staging-v02.api.letsencrypt.org-directory","error":"[cjcloud.us] solving challenges: presenting for challenge: adding temporary record for zone \"us.\": expected 1 zone, got 0 for us. (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/109035384/9519756664) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
{"level":"error","ts":1688183097.7552269,"logger":"tls.obtain","msg":"will retry","error":"[cjcloud.us] Obtain: [cjcloud.us] solving challenges: presenting for challenge: adding temporary record for zone \"us.\": expected 1 zone, got 0 for us. (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/109035384/9519756664) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":12,"retrying_in":21600,"elapsed":21608.943635038,"max_duration":2592000}
Script executes the following
iocage exec "${JAIL_NAME}" xcaddy build --output /usr/local/bin/caddy --with github.com/caddy-dns/"${DNS_PLUGIN}" where DNS_PLUGIN = cloudflare
#iocage exec "${JAIL_NAME}" sed -i '' "s/DNS-PLACEHOLDER/${DNS_SETTING}/" /usr/local/www/Caddyfile
iocage exec "${JAIL_NAME}" sed -i '' "s/dns_plugin/${DNS_PLUGIN}/" /usr/local/www/Caddyfile
iocage exec "${JAIL_NAME}" sed -i '' "s/api_token/${DNS_TOKEN}/" /usr/local/www/Caddyfile
iocage exec "${JAIL_NAME}" sed -i '' "s/jail_ip/${IP}/" /usr/local/www/Caddyfile
iocage exec "${JAIL_NAME}" sed -i '' "s/youremailhere/${CERT_EMAIL}/" /usr/local/www/Caddyfile
iocage exec "${JAIL_NAME}" sed -i '' "s|mytimezone|${TIME_ZONE}|" /usr/local/etc/php.ini
iocage exec "${JAIL_NAME}" sysrc caddy_enable="YES"
iocage exec "${JAIL_NAME}" sysrc caddy_config="/usr/local/www/Caddyfile"```
### a. System environment:
FreeBSD 13.1-RELEASE-p2 n245412-484f039b1d0 TRUENAS
### b. Command:
Commands are what you type into a terminal, i.e. the command you use to run Caddy.
Please read https://caddyserver.com/docs/running to understand the recommended commands to run Caddy, depending on your installation method.
```service caddy start
        # debug
        email myEmail@mail.com
        # default_sni cjcloud.us
cjcloud.us {
        root * /usr/local/www/nextcloud
                output file /var/log/cjcloud.us.log
        php_fastcgi 127.0.0.1:9000 {
                env front_controller_active true
                dns cloudflare <redacted>
                # enable HSTS
                # Strict-Transport-Security max-age=31536000;
        # client support (e.g. os x calendar / contacts)
        redir /.well-known/webfinger /index.php/.well-known/webfinger 301
        redir /.well-known/nodeinfo /index.php/.well-known/nodeinfo 301
        @forbidden {
                path /.htaccess
                path /data/*
                path /config/*
                path /db_structure
                path /.xml
                path /README
                path /3rdparty/*
                path /lib/*
                path /templates/*
                path /occ
                path /console.php
        respond @forbidden 404
I’m guessing something weird about your DNS setup. Do you have any nameservers / an authoritative zone?
This is my setup in cloudflare, the IP address is my WAN IP.
Thank you,
Justin
I am marking this as resolved, I needed to add the following under my tls block within my Caddyfile
     dns cloudflare redacted
     resolvers 1.1.1.1
To clarify, the reason this was needed is likely because your local DNS resolver is misconfigured.
Thank you, I did also add my DNS and associated IP to my routers /etc/hosts file as well.
