v2.3
caddy run --config=caddy.json
Ubuntu 20.04
Paste command here.
"apps": {
"http": {
"servers": {
"example": {
"listen": [":80",":443"],
"routes": [
"match": [{"host": ["example.com"]}],
"handle": [
"handler": "reverse_proxy",
"upstreams": [
{"dial":"xxx.xxx.xxx.xxx:5000"}]
Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
I want to redirect http://example.com to https://example.com. Because it is not working by default.
So for achieving this, i was thinking of using redir directive but didn’t find any example of using redir in json format file.
Please assist where should I put redir directive to redirect http://example.com → https://example.com
