I have Caddy behind Netlify using their proxy feature, and in front of some services in the local network.
One of them is Gitea, but looks like the X-Forwarded-* headers are not being forwarded correctly from the client, as when I open the login page there is a warning about it.
The proxy chain is
- gitea.kroltan.me (Netlify)
- home.kroltan.me:3003 (Caddy)
- riebeck.lan:3000 (Gitea)
The detected web site URL is “https://home.kroltan.me:3003/”, it’s unlikely matching the site config.
Mismatched app.ini ROOT_URL or reverse proxy “Host/X-Forwarded-Proto” config might cause wrong URL links for web UI/mail content/webhook notification/OAuth2 sign-in.
I understand this is the Caddy community I’m asking, I don’t want to make changes to Gitea to hide the warning. I want to adjust the server configuration to fix the underlying problem.
v2.11.4 h1:XKxkMTgNSizEvKG6QHue6cAsFOteU2qA61w2tKkCWi0=
FROM docker.io/caddy:2-builder-alpine AS builder
RUN xcaddy build \
--with github.com/caddy-dns/netlify \
--with github.com/ggicci/caddy-jwt
FROM docker.io/caddy:2-alpine
4a. System environment:
Up-to-date Fedora Server, Podman 5.8.2
4b. Command:
If you mean literally what ended up running, then:
But I’m using Podman so it was really systemctl --user start caddy.service
4c. Service/unit/compose file:
Wants=network-online.target
[Container]
Image=caddy.build
Volume=%h/caddy/data:/data:Z
Volume=%h/caddy/conf:/etc/caddy:ro,Z
PublishPort=8080:8080
PublishPort=3003:3003
PublishPort=44333:44333
Network=caddy.network
ContainerName=caddy
Secret=CADDY_JWS_KEY,type=env,target=JWS_KEY
WantedBy=default.target
4d. My complete Caddy config:
I have a couple utility includes and the main configuration files:
Caddyfile
http_port 8080
https_port 44333
http://* {
redir https://{host}:44333 308
# As an alternative to editing the above site block, you can add your own site
# block files in the Caddyfile.d directory, and they will be included as long
# as they use the .caddyfile extension.
import Caddyfile.d/*.caddyfile
public_reverse_proxy
route {
jwtauth {
sign_key {$JWS_KEY}
sign_alg HS256
user_claims netlify_id
from_header x-nf-sign
issuer_whitelist netlify
reverse_proxy {args[0]} {
# Only acceptable because we have authenticated Netlify above
trusted_proxies 0.0.0.0/0 ::/0
Caddyfile.d/forwards.caddyfile
https://home.kroltan.me:3003 {
# Gitea
import ../public_reverse_proxy http://riebeck.lan:3000
5. What I already tried, and links to relevant resources:
According to the reverse_proxy documentation, these headers are intentionally not propagated because they could be spoofed by a client, such as in the case the Caddy server is in fact public-facing.
Now, my server is only kind-of public facing, it has to be because I don’t have privileged port access on my ISP, so I have to put Netlify in front to get a nice URL. However, I don’t expect users to ever need to hit Caddy directly.
So I set up signed proxy redirects on Netlify, and added the jwtauth module to Caddy to ensure I am only serving requests coming through Netlify. That part is working! (I have verified by getting a 401 when trying to access the Caddy address directly from my browser)
However, even with the blanket trusted_proxiesassignment, it seems like the header is still not being properly forwarded. I’m not sure how to debug this either.
Assistance disclosure
No AI used.
