Copy_header copying empty headers with Authelia
I have Caddy set up with Authelia in docker. Everything works, but I have an issue with the copy_header putting empty headers when I have Authelia set to bypass authentication if I am accessing from my LAN.
My Caddyfile:
auth.mydomain.com {
	reverse_proxy authelia:9091
whoami.mydomain.com {
	forward_auth authelia:9091 {
		uri /api/authz/forward-auth
		copy_headers Remote-User Remote-Groups Remote-Email Remote-Name
	reverse_proxy whoami:80
In my Authelia config, I use this to bypass for LAN access:
access_control:
  default_policy: deny
  rules:
    - domain: '*.mydomain.com'
      policy: bypass
In this setup when access whoami.mydomain.com from my LAN, the headers in the copy_header directive above look like so:
Remote-Email: {http.reverse_proxy.header.Remote-Email}
Remote-Groups: {http.reverse_proxy.header.Remote-Groups}
Remote-Name: {http.reverse_proxy.header.Remote-Name}
Remote-User: {http.reverse_proxy.header.Remote-User}
When accessing from outside the bypassed net in Authelia (i.e., when I am not on my LAN and therefore have to authenticate through Authelia), they are populated with the values from Authelia like normal:
Referer: https://auth.mydomain.com/
Remote-Email: steve@mydomain.com
Remote-Groups: admins
Remote-Name: Steve
Remote-User: steve
Is there a way I can prevent this from happening? That is, just don’t put the headers in there when thy are empty?
There are no errors or messages in the logs when this happens
Docker install on debian 10 with image caddy:latest.
docker compose up
:slight_smile:
    image: caddy:latest
    cap_add:
      - NET_ADMIN
      - $PWD/site:/srv
      - $PWD/caddy_data:/data
      - $PWD/caddy_config:/config
  authelia:
    container_name: 'authelia'
    image: 'authelia/authelia'
    restart: 'unless-stopped'
      - $PWD/authelia_config:/config
  whoami:
    container_name: 'whoami'
    image: 'traefik/whoami'
shown above
none
Hmm yeah that’s unfortunate. I’ll try to implement a fix for forward_auth to not do that.
But for now as a workaround you can use the long form forward_auth (Caddyfile directive) — Caddy Documentation but change the request_header part to read like this:
@Remote-User not vars {rp.header.Remote-User} ""
request_header @Remote-User Remote-User {rp.header.Remote-User}
@Remote-Groups not vars {rp.header.Remote-Groups} ""
request_header @Remote-Groups Remote-Groups {rp.header.Remote-Groups}
@Remote-Email not vars {rp.header.Remote-Email} ""
request_header @Remote-Email Remote-Email {rp.header.Remote-Email}
@Remote-Name not vars {rp.header.Remote-Name} ""
request_header @Remote-Name Remote-Name {rp.header.Remote-Name}
This is annoying boilerplate, but what this does is use a matcher on each header to check that the value is not empty before applying it to the request.
I implemented a fix here:
Thanks! I’ll see if I can check it out this weekend. As a workaround, I used a couple of handles and matchers to only call forward_auth for external IPs. Not sure which is more secure, if any
