2.3.0
as a service
Debian 10 Buster with Caddy as a service, no docker
paste command here
nc2-test.hfw18 {
root * /var/www/nextcloud
encode gzip zstd
tls internal
# php_fastcgi 127.0.0.1:9000 {
php_fastcgi unix//run/php/php7.4-fpm.sock {
env front_controller_active true
output file /var/log/caddy_nc.log
@forbidden {
path /.htaccess
path /data/*
path /config/*
path /db_structure
path /.xml
path /README
path /3rdparty/*
path /lib/*
path /templates/*
path /occ
path /console.php
respond @forbidden 404
I would like to enable Client Push/High Performance Backend in my Nextcloud. There for I have to proxy a folder to a local port.
The vhost snippet for nginx looks like this:
location /push/ {
proxy_pass http://localhost:7867/;
proxy_http_version 1.1;
proxy_set_header Connection “Upgrade”;
proxy_set_header Host $host;
To convert this into my Caddyfile is it as easy as inserting this line:
reverse_proxy /push/* http://localhost:7867
into the “nc2-test.hfw18” block?
From what I red so far the header instructions are deafults in Caddy, right?
What about the http version? Also default?
