Convert web.config to Caddyfile
For strange reasons I won’t go into much detail on, I’m looking to run vBulletin on Caddy. I’ll try to summarise by saying I intend to run multiple webapps on the server, and as part of a migration away from vBulletin I’d like to run it using Caddy.
I have both the htaccess and the web.config file, and I’m trying to do conditional rewrites, but I suspect there is more I need to do, and I don’t even know how to do this. If anyone could advise that’d be great… Here’s a dump of web.config:
<?xml version="1.0" encoding="UTF-8"?>
<!-- This file is to support redirection in IIS.
This file is harmless if you are running under Apache -->
<configuration>
	<system.webServer>
		<rewrite>
			<rules>
				<clear /> <!-- reset other rewrite rules -->
				<rule name="Css" stopProcessing="true">
					<match url="^css.php$" ignoreCase="false" />
					<action type="Rewrite" url="core/css.php" />
				</rule>
				<rule name="Installer" stopProcessing="true">
					<match url="^install/" ignoreCase="true" />
					<action type="Rewrite" url="core/install/" />
				</rule>
				<rule name="Main Redirect" stopProcessing="true">
					<match url="^(.*)$" ignoreCase="false" />
					<conditions logicalGrouping="MatchAll">
						<add input="{REQUEST_FILENAME}" matchType="IsFile" ignoreCase="false" negate="true" />
						<add input="{REQUEST_FILENAME}" matchType="IsDirectory" ignoreCase="false" negate="true" />
					</conditions>
					<action type="Rewrite" url="index.php?routestring={R:1}" />
				</rule>
				<rule name="Admincp" stopProcessing="true">
					<match url="^(admincp/)$" ignoreCase="false" />
				</rule>
			</rules>
		</rewrite>
	</system.webServer>
</configuration>
The htaccess file looks a bit more complex, I’m not sure how much of it is actually essential, though…
<IfModule mod_rewrite.c>
	RewriteEngine On
	# In some cases where you have other mod_rewrite rules, you may need to remove the
	# comment on the following RewriteBase line and change it to match your folder name.
	# This resets the other mod_rewrite rules for just this directory
	# If your site was www.example.com/forum, the setting would be /forum/
	#RewriteBase /
	# Send css calls directly to the correct file VBV-7807
	RewriteRule ^css.php$ core/css.php [NC,L]
	# Redirect old install path to core.
	RewriteRule ^install/ core/install/ [NC,L]
	# Main Redirect
	RewriteCond %{REQUEST_URI} !\.(gif|jpg|jpeg|png|css)$
	RewriteCond %{REQUEST_FILENAME} !-f
	RewriteCond %{REQUEST_FILENAME} !-d
	RewriteRule ^(.*)$ index.php?routestring=$1 [L,QSA]
	# Because admincp is an actual directory.
	RewriteRule ^(admincp/)$ index.php?routestring=$1 [L,QSA]
</IfModule>
<IfModule mod_deflate.c>
    AddOutputFilterByType DEFLATE application/atom+xml \
                          text/javascript \
                          application/x-javascript \
                          application/javascript \
                          application/json \
                          application/rss+xml \
                          application/vnd.ms-fontobject \
                          application/x-font-ttf \
                          application/xhtml+xml \
                          application/xml \
                          font/opentype \
                          image/svg+xml \
                          image/x-icon \
                          text/css \
                          text/html \
                          text/plain \
                          text/x-component \
                          text/xml
</IfModule>
<IfModule mod_expires.c>
	ExpiresActive On
	ExpiresByType application/x-javascript A1209600
	ExpiresByType text/javascript A1209600
	ExpiresByType application/javascript A1209600
	ExpiresByType text/css A31536000
	ExpiresByType image/x-icon A2592000
	ExpiresByType image/icon A2592000
	ExpiresByType application/x-ico A2592000
	ExpiresByType application/ico A2592000
	ExpiresByType image/gif A2592000
	ExpiresByType image/jpeg A1209600
	ExpiresByType image/jpg A1209600
	ExpiresByType image/png A1209600
	ExpiresByType application/x-shockwave-flash A1209600
	ExpiresByType font/ttf A2592000
	ExpiresByType font/otf A2592000
	ExpiresByType font/x-woff A2592000
	ExpiresByType image/svg+xml A2592000
	ExpiresByType font/truetype A2592000
	ExpiresByType font/opentype A2592000
	ExpiresByType application/x-font-woff A2592000
	ExpiresByType application/vnd.ms-fontobject A2592000
</IfModule>
<IfModule mod_headers.c>
    Header set Connection keep-alive
	<filesmatch "\.(ico|flv|gif|swf|eot|woff|otf|ttf|svg)$">
		Header set Cache-Control "max-age=2592000, public"
	</filesmatch>
	<filesmatch "\.(jpg|jpeg|png)$">
		Header set Cache-Control "max-age=1209600, public"
	</filesmatch>
	<filesmatch "\.(eot|woff|otf|ttf|svg)$">
	</filesmatch>
	# css and js should use private for proxy caching https://developers.google.com/speed/docs/best-practices/caching#LeverageProxyCaching
	<filesmatch "\.(css)$">
		Header set Cache-Control "max-age=31536000, private"
	</filesmatch>
	<filesmatch "\.(js)$">
		Header set Cache-Control "max-age=1209600, private"
	</filesmatch>
</IfModule>
So far, I’ve just about managed to fix the CSS with the following rewrite:
rewrite {
    r css.php
    to core/css.php
But I still have a long way to go, and I don’t even know if/why this might (not) work.
This is all more-or-less doable, I think. You’ll need to be a bit handy, though, because I can see it requiring a bit of experimentation and troubleshooting.
Let me take a crack at that .htaccess. You’re on the right track with that rewrite, but you can be a tad more precise, I think (and avoid going anywhere near a regex, even if there’s no actual regular expression in it).
The following is done quickly by hand and completely untested.
rewrite /css.php /core/css.php
rewrite /install {
    to /core/install
# Main Redirect
rewrite {
    ext !gif !jpg !jpeg !png !css
    to {path} {path}/ index.php?routestring={uri}
rewrite /admincp {
# <IfModule mod_deflate.c> section
gzip # Ha ha.
# <IfModule mod_expires.c> section
# Requires third-party plugin https://caddyserver.com/docs/expires
expires {
    match .js$ 14d # 1209600 = 14 days
    match .css$ 1y # 31536000 = 365 days - wow, seems a little long for CSS
    match .(gif|jpg|jpeg|png|ttf|otf|woff|svg)$ 1m # 2592000 = 30 days
Didn’t bother with the <IfModule mod_headers.c> section, looks like just a bunch of cache control, should be handled by expires if you use it.
Thanks, I will have a crack at it shortly and let you know how I get on - busy times right now :slight_smile:
