Convert V1 caddyfiles to v2?
docker: abisoft/caddy:latest
multiple sites loaded from multiple caddyfiles via
import /opt/docker/caddy/sites/*.conf
Docker:
caddy --conf /opt/caddy/Caddyfile --log stdout --agree=$ACME_AGREE
Docker,
main caddyfile
import /opt/caddy/sites/*conf
anything with a comment, indicates a seperate file
## basic redicts
http://codeexample.com {
        redir https://example.com
http://(server IP addr) {
# file server
https://cdn.example.com {
        tls /opt/caddy/cert/pub /opt/caddy/cert/priv
        root /opt/fileserver/
        log /opt/caddy/log/cdn.log
	errors /opt/caddy/log/cdn.err
        browse /
	basicauth /games/	user password
	markdown /
# code-server
https://code.example.com {
        basicauth / user password
        proxy / 192.168.0.115:8080 {
		websocket
        log /opt/caddy/log/vscode.log
	errors /opt/caddy/log/vscode.log
        proxy /http 192.168.0.115:8081 {
# gitea
https://git.example.com {
#	redir / https://github.com/Merith-TK
	log /opt/caddy/log/git.log
	errors /opt/caddy/log/git.log.err
	proxy / 172.17.0.3:3000 {
		websocket
# mailcow
https://mail.example.com {
        log /opt/caddy/log/mail.log
        errors /opt/caddy/log/mail.err
	proxy / 127.0.0.1:8084	 {
		websocket
# nextcloud
https://next.example.com {
        root /opt/nextcloud/
        log /opt/caddy/log/next.log
        errors /opt/caddy/log/next.err
	proxy / 192.168.0.101:8081 {
		websocket
http://next.example.com {
  redir https://{host}{uri}
# main website
https://example.com, https://www.example.com {
        root /opt/caddy/websites/www
        index index.html
        log /opt/caddy/log/www.log
	errors /opt/caddy/log/www.err
I have no clue in converting v1 configs to v2,
I had to convert a config on my phone and converting something as simple as
http://localhost:8080 {
browse /sdcard/WWW/
index .html
root ./
was a nightmare for me
No errors,
I have no clue what im doing at all
Thankfully, we have an upgrade guide that will make it a lot less nightmare-ish! :slight_smile: Upgrading to Caddy 2 — Caddy Documentation
I would recommend just starting with a clean slate for v2. Much easier than trying to do a 1:1 conversion.
as you can see, i have alot of configs (definately not the most, but alot)
this will be quite difficult for me as im used to one format.
if caddyv2 couldve supported v1 configs by having a flag like config 1 or config 2 for the caddyversion, that wouldve been nice
There is no directive for the errors /opt/caddy/log/cdn.err config from v1 that i can find for v2,
this is kinda important so i can check who accessed what separately from what errors caddy throws out
edit:
Also how do i reverse proxy websockets with a transperant proxy? are those configs the same? or have they been relabeled like litterally 80% of everything else
Unfortunately, Caddy v2’s complete, from-the-ground-up rewrite prevents any kind of config logic from v1 from being remotely applicable to v2. Any kind of backwards compatibility would have to take the form of an interpreting/translating layer converting v1 Caddyfile to v2 config.
In fact, Caddy’s native config language is JSON. The v2 Caddyfile isn’t even directly applicable to Caddy v2 configuration! It has to be adapted first. But even so, some of the ways v1 did things - and many of the assumptions about how that configuration effected things - are done totally differently under the hood now and it’d be dangerous to give the impression that a literal translation will always achieve the same result in v2.
I’d suggest that if you don’t have a log parser that can handle filtering, you can do a quick-and-dirty grep for something like "status": 4 or "status": 5 which should limit the results to error responses.
Alternatively, you can go down to the JSON to configure log outputs and including/excluding whatever arbitrary content you might like: JSON Config Structure - Caddy Documentation
Reverse proxy transparency, and websockets, are now completely automatic and require no extra configuration.
