How can I adapt the following Nginx config with Caddy in Docker:
server {
root /var/www/public;
index index.php;
server_name darkrate.com www.darkrate.com;
location /ws/ {
proxy_pass http://212.162.152.250:8081/ws/;
proxy_set_header Connection 'upgrade';
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
proxy_set_header X-Forwarded-Proto $scheme;
location /es {
proxy_pass http://127.0.0.1:8088/es;
proxy_read_timeout 86400;
location /phantom {
proxy_pass http://127.0.0.1:8083;
location /exchange/ {
rewrite ^/exchange/(.*)$ /$1 redirect;
# add_header Cache-Control "max-age=31536000, public, s-maxage=31536000";
location /exchanger/ {
rewrite ^/exchanger/(.*)$ /exchangers/$1 redirect;
location / {
proxy_pass http://127.0.0.1:3000;
rewrite ^/(.*)/$ /$1 permanent;
location /admin {
alias /var/www/public/;
try_files $uri $uri/ @admin;
location ~ \.php$ {
include snippets/fastcgi-php.conf;
fastcgi_param SCRIPT_FILENAME $request_filename;
fastcgi_pass php-fpm:9000;
location @admin {
rewrite /admin/(.*)$ /admin/index.php?/$1 last;
location ~ \.php$ {
location ~ /\.ht {
deny all;
if ($host = www.darkrate.com) {
return 301 https://darkrate.com$request_uri;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/darkrate.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/darkrate.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
return 301 https://$host$request_uri;
} # managed by Certbot
if ($host = darkrate.com) {
listen 80;
return 404; # managed by Certbot
Fastcgi snippets:
# regex to split $uri to $fastcgi_script_name and $fastcgi_path
fastcgi_split_path_info ^(.+?\.php)(/.*)$;
# Check that the PHP script exists before passing it
try_files $fastcgi_script_name =404;
# Bypass the fact that try_files resets $fastcgi_path_info
# see: http://trac.nginx.org/nginx/ticket/321
set $path_info $fastcgi_path_info;
fastcgi_param PATH_INFO $path_info;
fastcgi_index index.php;
include fastcgi.conf;
Caddy version: v2.7.6
Docker version: 24.0.5
