Convert nginx config to caddyfile for minio site replication
I want to use caddy as load balancer fo my minio’s multi-node setup. I found a guide from minio blog with this nginx config:
upstream minio_server {
    server server-1.minio.local:9000;
    server server-2.minio.local:9000;
    server server-3.minio.local:9000;
server {
    listen   	80 default_server;
    ignore_invalid_headers off;
    client_max_body_size 0;
    proxy_buffering off;
    proxy_request_buffering off;
    location / {
        proxy_set_header Host $http_host;
        proxy_set_header X-Forwarded-Proto $scheme;
        proxy_connect_timeout 300;
        proxy_http_version 1.1;
        proxy_set_header Connection "";
        chunked_transfer_encoding off;
        proxy_pass http://minio_server;
How do i convert it to caddyfile? I tried converting it (caddyfile below), run mc admin replicate add <alias1> <alias2> with the alias being the caddy’s server, but it returns remote service endpoint unavailable. But if i run mc admin info <alias>, it works fine, so I’m guessing i convert the nginx config wrongly.
n/a
systemd
Type=notify
My current caddyfile that i try to convert:
minio.mydomain.com {
  tls internal
  request_body {
    max_size 0
  reverse_proxy minio-1.mydomain.com:9000 minio-2.mydomain.com:9000 {
     flush_interval -1
     health_uri /minio/health/live
     lb_policy round_robin
     lb_try_duration 10s
For anyone having this same issue, the problem is in self-signed certificate. When using site replication, minio itself is the one connecting to caddy. By adding --certs-dir in minio startup argument and adding caddy’s root ca to /CAs, the site replication succeed.
