Context handling in modules
Hi,
I wanted to inquire what the best way is to propagate cancel down to my module.
For context (no pun intended), I am working on a plugin/module that uses SSE. I think my SSE handler currently blocks the shutdown procedure of the Caddy process, and I’d like to clean it up before I release it. So far, I tried to work around it with another channel to make it respond to stop, but it feels dirty.
func (cs *CaddyScope) serveAPIStream(w http.ResponseWriter, r *http.Request) {
  w.Header().Set(“Content-Type”, “text/event-stream”)
  w.Header().Set(“Cache-Control”, “no-cache”)
  w.Header().Set(“X-Accel-Buffering”, “no”)
  rc := http.NewResponseController(w)
  writeAndFlush := func(data []byte) error {
	if _, err := fmt.Fprintf(w, "event: stats\ndata: %s\n\n", data);     err != nil {
	  return err
	return rc.Flush()
  if data := cs.snap.get(); data != nil {
	if err := writeAndFlush(data); err != nil {
	  return
  ticker := time.NewTicker(time.Duration(cs.Refresh))
  defer ticker.Stop()
  for {
	select {
	case <-r.Context().Done():
	  return
	case <-cs.cancelCtx.Done():
	  return
	case <-ticker.C:
	  if data == nil {
		continue
		return
I think there’s two things/questions here.
  • Blocking Caddy shutdown
  • Cleaning up (shutting down “cleanly”)
Why do you think your plugin is blocking the Caddy shutdown? Do you have a link to the code somewhere?
When I disable my plugin, caddy gets the “ctrl+c” and exists right away. With my plugin, it doesn’t. As I said, I’ve tried to work around with another channel, but it just feels dirty.
Is the behaviour the same if you set grace_period in global options?
I think it’ll be hard to answer for sure without seeing your code, and/or a profile at the time of program exit.
I’ll work on cleaning it up, I had hoped for some general guidance regarding context handling/propagation — or some example modules.
