Content-type missing charset info
Using Docker
FROM caddy:2.0.0
Docker
Using curl to get a json file stored in my document root
curl -v https://dx.mydomain.org/jsonfile.json
FROM caddy:2.0.0
COPY index.html /srv/index.html
RUN caddy validate --config /etc/caddy/Caddyfile
dx.mydomain.org {
    # Define Customer IP ranges
    @memyself {
        # Of course not the real IP
        remote_ip 146.131.23.0/24
    # Define actions for customers
    handle @memyself {
        file_server {
            root /var/www
    # Default: Redirect to my Main Page
        redir * https://www.mydomain.org/
I have a json file in UTF-8 on that server which is returned to me like this:
$ curl -v https://dx.mydomain.org/jsonfile.json > x
*   Trying 123.123.123.123...
* TCP_NODELAY set
* Connected to dx.mydomain.org (123.123.123.123) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
*   CAfile: /etc/ssl/cert.pem
  CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
} [230 bytes data]
* TLSv1.2 (IN), TLS handshake, Server hello (2):
{ [64 bytes data]
* TLSv1.2 (IN), TLS handshake, Certificate (11):
{ [2372 bytes data]
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
{ [115 bytes data]
* TLSv1.2 (IN), TLS handshake, Server finished (14):
{ [4 bytes data]
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
} [37 bytes data]
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
} [1 bytes data]
* TLSv1.2 (OUT), TLS handshake, Finished (20):
} [16 bytes data]
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
{ [1 bytes data]
* TLSv1.2 (IN), TLS handshake, Finished (20):
{ [16 bytes data]
* SSL connection using TLSv1.2 / ECDHE-ECDSA-AES256-GCM-SHA384
*  subject: CN=dx.mydomain.org
*  start date: Jul 11 12:15:35 2020 GMT
*  expire date: Oct  9 12:15:35 2020 GMT
*  subjectAltName: host "dx.mydomain.org" matched cert's "dx.maydomain.org"
*  issuer: C=US; O=Let's Encrypt; CN=Let's Encrypt Authority X3
* Using Stream ID: 1 (easy handle 0x7fa67780d800)
> GET /jsonfile.json HTTP/2
> Host: dx.mydomain.org
> User-Agent: curl/7.54.0
* Connection state changed (MAX_CONCURRENT_STREAMS updated)!
< HTTP/2 200
< accept-ranges: bytes
< content-type: application/json
< etag: "qe4ckx4ownr"
< last-modified: Mon, 27 Jul 2020 08:22:09 GMT
< server: Caddy
< content-length: 7880535
< date: Mon, 27 Jul 2020 10:28:54 GMT
{ [5886 bytes data]
No error message, but I get
But would expect
content-type: application/json; charset=UTF-8
Checked issues in the forum and just found some explaining stuff about “mime” which I couldn’t make use of as I did not find any documentation about it. Putting it into the Caddyfile nonetheless resulted in errors:
{"level":"info","ts":1595845120.982867,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
validate: adapting config using caddyfile: /etc/caddy/Caddyfile:12: unrecognized directive: mime
Please upgrade to the latest version, i.e. 2.1.1 which has some important fixes. If I remember correctly, we added the mailcap package to the docker image since that version.
Did so. Didn’t change anything.
Could you please tell me how the mailcap package can help me?
Ah, I think I sorta misunderstood the issue. I apologize for reading too quickly. Anyways, mailcap is “mail capability”, it provides the MIME type lookup table that the Go standard lib uses. At one point, it was missing from the docker image so some users were running into issues with content types.
Your question is different in that it relates more specifically to the charset. As an aside, I’ve always understood that as being optional. Where is that causing issues for you exactly, out of curiosity?
One fix would be to override the header if the request is for a .json file:
@isJson path *.json
header @isJson Content-Type "content-type: application/json; charset=UTF-8"
T.b.h. In the meantime I learned that it is no issue at all. The issue lay in a “double encoding” I did when saving the downloaded file. So my issue is solved now, but your last reply is very helpful as it shows me how to set the header based on file extension. I couldn’t figure that out as the documentation (to me) seems very unstructured and/or incomplete.
Small correction. It should be
@isJson path *.json
header @isJson Content-Type "application/json; charset=UTF-8"
Ah yep, my mistake, bad copy-paste while on my phone :smile:
Glad you figured out the issue.
