I’d like to set up Caddy as a reverse proxy for SemaphoreUI. Both in containers (used Podnam to run those). To make it even trickier it’s behind Cloudflare (use custom image of Caddy with cloudflare plugin).
I get it somewhat working. I get HTTPS and the site itself launches. But I recieve websocket errors. I’ve looked into sample configs on SemaphoreUI site:
Sadly they do not provide samples for Caddy and I fail to recreate the entries from Nginx / Apache.
After searching I`ve tried adding:
@ws {
header Connection *Upgrade*
header Upgrade websocket
reverse_proxy semaphoreui/api/ws
But that didn’t work.
time="2024-05-23T22:05:13+02:00" level=error msg="websocket: close 1005 (no status)" fields.level=Error
time="2024-05-23T22:05:13+02:00" level=error msg="websocket: close sent" fields.level=Error
time="2024-05-23T22:05:13+02:00" level=error msg="close tcp 10.89.0.25:3000->10.89.0.24:35370: use of closed network connection" fields.level=Error
2024-05-23 22:05:28.405 CEST [21] LOG: checkpoint starting: time
It’s installed in containers. Here’s the compose file:
image: caddy-cloudflare
restart: always
env_file:
- $PWD/.ENV/.caddy
cap_add:
- NET_ADMIN
- "443:443/udp"
- $PWD/Caddyfile:/etc/caddy/Caddyfile:z
- $PWD/site:/srv:z
- $PWD/caddy_data:/data:z
- $PWD/caddy_config:/config:z
- caddynet
postgres:
image: postgres:16
hostname: postgres
- $PWD/semaphore-postgres:/var/lib/postgresql/data:z
env_file:
- $PWD/.ENV/.semaphore
- semnet
semaphore:
image: semaphoreui/semaphore:latest
env_file:
- caddynet
- semnet
- $PWD/semaphore-data:/etc/semaphore:Z
- $PWD/semaphore-extras/requirements.txt:/etc/semaphore/requirements.txt
caddynet:
driver: bridge
semnet:
internal: true
Podman on Rocky9.
Here’s the Caddyfile:
mydomain.site {
X-Robots-Tag "none"
-Server
dns cloudflare {env.CF_API_TOKEN}
resolvers 1.1.1.1
reverse_proxy semaphore:3000 {
Btw - apart from online docs does anyone know of a book about Caddy? Preferably for a dummy .
