For a little bit more context, I am in the process of setting up a SaaS project using docker, laravel, php-fpm and caddy. New customers (tenants) will receive a subdomain automatically (e.g tenant1.ciro.com). This appears to be working well for me locally as I can hit admin.ciro.localhost, ciro.localhost and tenant1.ciro.localhost.
Tenants also have the option of specifying a custom domain as well. For this test, I am trying to hit test.localhost. For this I have tried to setup on_demand_tls and have setup an endpoint to validate the domain that caddy is passing me. Below is how I validate this (it does appear to work fine, and doesn’t seem to be the cause of the probilem I am having).
<?php
namespace App\Http\Controllers;
use App\Store;
use Illuminate\Http\Request;
class CaddyController extends Controller
public function check(Request $request)
$authorizedDomains = [
'test.localhost'
if (in_array($request->query('domain'), $authorizedDomains)) {
return response('Domain Authorized');
// Abort if there's no 200 response returned above
abort(503);
The next part is where my issues start to arise.
When the caddy container runs the ask endpoint, I get a connection refused error. My guess is that I am not calling my dockerized laravel service, ciro, correctly from the caddy container.
I have setup a bridge network that the caddy and ciro containers are both configured to use, but for some reason I am unable to communicate from the caddy container to ciro.
I have also tried going directly into the caddy container and running curl against the endpoints with similar results:
ciro on main [!] via v16.17.1 via 🐘 v8.2.3 took 18m5s
❯ docker exec -ti caddy /bin/sh
/var/www/html # curl -i https://ciro:5555
curl: (7) Failed to connect to ciro port 5555 after 2 ms: Connection refused
/var/www/html # curl -i https://ciro:9000
curl: (7) Failed to connect to ciro port 9000 after 1 ms: Connection refused
/var/www/html # curl -i ciro:9000
curl: (7) Failed to connect to ciro port 80 after 1 ms: Connection refused
/var/www/html # curl -i ciro:5173
curl: (7) Failed to connect to ciro port 5173 after 1 ms: Connection refused
Any help would be much appreciated! ![]()
"level": "error",
"ts": 1678556751.8410308,
"logger": "tls",
"msg": "request to 'ask' endpoint failed",
"error": "error checking https://ciro:5173/caddy-check to determine if certificate for hostname 'test.localhost' should be allowed: Get \"https://ciro:5173/caddy-check?domain=test.localhost\": dial tcp 192.168.192.6:5173: connect: connection refused",
"endpoint": "https://ciro:5173/caddy-check",
"domain": "test.localhost"
Here is my dockerfile I use to build Caddy:
FROM caddy:2.6.4-builder AS builder
RUN xcaddy build \
FROM caddy:2.6.4
Via offical caddy Docker Container via docker compose.
Here is my docker-compose.yml that sets up my ciro laravel application and caddy… I have removed the other unecessary services like memcached and mysql for easier reading:
version: '3'
ciro:
container_name: ciro
build:
context: ./docker/8.2
dockerfile: Dockerfile
args:
WWWGROUP: '${WWWGROUP}'
image: ciro-8.2/app
extra_hosts:
- 'host.docker.internal:host-gateway'
- '5173:5173'
WWWUSER: '${WWWUSER}'
LARAVEL_SAIL: 1
XDEBUG_MODE: '${SAIL_XDEBUG_MODE:-off}'
XDEBUG_CONFIG: '${SAIL_XDEBUG_CONFIG:-client_host=host.docker.internal}'
- '.:/var/www/html'
- 'sail-unix-sockets:/var/run'
- sail
depends_on:
- mysql
- memcached
- mailpit
image: caddy-cloudflare:latest
working_dir: /var/www/html
command: 'caddy run'
APP_URL: '${APP_URL}'
HTTP_SCHEME: '${HTTP_SCHEME}'
- '${APP_PORT:-80}:80'
- sail
- './:/var/www/html'
- 'sail-caddy-data:/data'
- 'sail-caddy-config:/config'
sail:
driver: bridge
sail-mysql:
driver: local
sail-caddy-data:
sail-caddy-config:
sail-unix-sockets:
on_demand_tls {
# TODO
# No such host .. something docker related I would imagine.
ask https://ciro:5173/caddy-check
local_certs
*.{$APP_URL}, {$APP_URL} {
# For local development use internal
# https://caddyserver.com/docs/caddyfile/directives/tls#examples
tls internal
root * {$SITE_ROOT_PATH:./public}
X-Frame-Options SAMEORIGIN
x-Content-Type-Options nosniff
@cacheItems path_regexp \.(css|ico|js|woff2)*
header @cacheItems Cache-Control "max-age=31536000, immutable"
encode zstd gzip
php_fastcgi {$PHP_FASTCGI_LISTEN:unix//var/run/php/php8.2-fpm.sock}
:443 {
on_demand
NA
