Hi,
today i went to replace nginx with caddy and I read through several documentation to finally got a proper configuration for caddy. However, when I try to start it, browsers say: Connection refused.
I built Caddy from the Download site of caddyserver.com and use Debian 9.
Golang is installed: go1.7.4 linux/amd64.
My configuration is:
http://henrock.net {
redir https://henrock.net
http://www.henrock.net {
redir https://www.henrock.net
http://blog.henrock.net {
redir https://blog.henrock.net
http://ssl.henrock.net {
redir https://ssl.henrock.net
https://henrock.net {
tls ssl/my.crt ssl/my.key {
protocols tls1.0 tls1.2
ciphers ECDHE-ECDSA-AES256-GCM-SHA384 ECDHE-ECDSA-AES128-GCM-SHA256 ECDHE-ECDSA-AES256-CBC-SHA ECDHE-ECDSA-AES128-CBC-SHA
curves p521 p384 p256
gzip {
ext *
level 4
fastcgi html unix:/var/run/php5-fpm.sock {
root html/henrock.net
connect_timeout 20s
read_timeout 30s
send_timeout 120s
header html {
X-Frame-Options "DENY"
errors {
log log/error.log
404 errdoc/404.html # Not Found
500 errdoc/500.html # Internal Server Error
ext .html .htm .php
minify html/henrock.net/js html/henrock.net/css
log log/access.log
https://www.henrock.net {
gzip {
ext *
level 4
connect_timeout 20s
read_timeout 30s
send_timeout 120s
header html {
errors {
log log/error.log
ext .html .htm .php
log log/access.log
https://blog.henrock.net {
gzip {
ext *
level 4
root html/blog.henrock.net
connect_timeout 20s
read_timeout 30s
send_timeout 120s
header html {
errors {
log log/error.log
ext .html .htm .php
minify html/blog.henrock.net/js html/blog.henrock.net/css
log log/access.log
https://ssl.henrock.net {
gzip {
ext *
level 4
root html/ssl.henrock.net
connect_timeout 20s
read_timeout 30s
send_timeout 120s
header html {
errors {
log log/error.log
log log/access.log
browse html/ssl.henrock.net
Folders and files, mentioned in the config (errdoc, log, html, ssl), do exist and I run caddy as root because of flexibility purposes (and because I like pain ;-)).
My start command for Caddy is: ./caddy -quic -conf="caddy.cf" -port 443 -agree
Additionally, both my access.log and my error.log files remain empty for some reason…
Thanks,
Henrik
