Connection errors with mTLS enabled upstream service under load
2.3.0
Running in Docker, Ubuntu Image
Caddy and Upstream services are running in Docker in a k8s cluster
Paste command here.
	"admin": {
		"disabled": false,
		"listen": "0.0.0.0:2019"
	"apps": {
		"http": {
			"servers": {
				"srv0": {
					"listen": [":443"],
					"listener_wrappers": [{
							"wrapper": "proxy_protocol",
							"timeout": "5s"
							"wrapper": "tls"
					"routes": [
							"match": [{
								"host": ["api.domain"]
							"handle": [{
								"handler": "subroute",
								"routes": [{
									"handle": [{
											"handler": "headers",
											"response": {
												"set": {
													"Server": ["OurServer"]
											"handler": "custom_caddy_module"
											"handler": "reverse_proxy",
											"transport": {
												"protocol": "http",
												"tls": {
													"client_certificate_file": "/etc/internal-certs/cert.pem",
													"client_certificate_key_file": "/etc/internal-certs/key.pem",
													"root_ca_pem_files": ["/etc/ca-certs/ca_crt.pem"]
											"upstreams": [{
												"dial": "api:443"
							"terminal": true
					"tls_connection_policies": [{
							"match": {
								"sni": ["api.domain"]
							"client_authentication": {
								"mode": "verify_if_given",
								"trusted_ca_certs_pem_files": ["/etc/certificates/ca.pem"]
							"match": {
								"sni": ["ui.domain"]
		"tls": {
			"certificates": {
				"load_files": [{
						"certificate": "/etc/certs/ui.pem",
						"key": "/etc/certs/ui-key.pem",
						"tags": ["ui"]
						"certificate": "/etc/certs/api.pem",
						"key": "/etc/certs/api-key.pem",
						"tags": ["api"]
We have a mTLS enabled server(upstream) and use Caddy as a reverse-proxy for it. We provide tls config in the caddy.json so that caddy can present certs while connecting with the upstream (api). This works fine in normal scenario/usage.
However, if we try running load of around 25 parallel users, we start seeing errors in Caddy. If we disable the mTLS and run the same load again, we do not see any errors.
Errors on Caddy:
ERROR http.log.error EOF {“request”: {“remote_addr”: “1x”, “proto”: “HTTP/1.1”, “method”: “POST”, “host”: “api.domain”, “uri”: “/api/…”, “headers”: {“User-Agent”: [“Apache-HttpClient/4.5.12 (Java/1.8.0_212)”], “Connection”: [“keep-alive”], “Content-Type”: [“application/json”], “Accept”: [“application/json”], “Authorization”: [“Bearer”], “Content-Length”: [“111”]}, “tls”: {“resumed”: false, “version”: 771, “cipher_suite”: 49200, “proto”: “”, “proto_mutual”: true, “server_name”: “api.domain”}}, “duration”: 0.017468929, “status”: 502, “err_id”: “dp6i1yxcc”, “err_trace”: “reverseproxy.statusError (reverseproxy.go:783)”}
Error log on the upstream server (Node JS server)
“name”: “api”,
“hostname”: “api-d9995-62g5r”,
“pid”: 1,
“level”: 50,
“type”: “ERROR”,
“error”: {
“message”: “request aborted”,
“code”: “ECONNABORTED”,
“expected”: 29,
“length”: 29,
“received”: 0,
“type”: “request.aborted”
“ip_address”: “1…”,
“request”: {
“method”: “PUT”,
“path”: “/api/…”,
“body”: {},
“query”: {},
“params”: {},
“headers”: {
“user-agent”: “Apache-HttpClient/4.5.12 (Java/1.8.0_212)”,
“content-length”: “29”,
“accept”: “application/json”,
“content-type”: “application/json”,
“x-forwarded-for”: “…”,
“x-forwarded-proto”: “https”,
“accept-encoding”: “gzip”
“msg”: “request aborted”,
Tried disabling mTLS and running the same load, no errors observed.
Tried specifying max_conns_per_host to 15 to limit max connections, still same errors occur
Error Code on the node js upstream server body-parser/README.md at master · expressjs/body-parser · GitHub
Please upgrade to v2.4.6 and try again. It’s possible that changes since have resolved your issue.
