1. Caddy version (caddy version): 2.1.1-alpine
Actually I don’t have a working configuration so far.
Hardware: Raspberry pi 4,
raspberry os: 4.19.118-v71+
Systemd: 241
Docker: 18.09.01
No command so far
My current docker-compose configuration with traefik
(it works fine except for the adguardhome part: see below)
default:
driver: bridge
traefik:
container_name: traefik
image: traefik:latest
labels:
- "traefik.enable=true"
- "traefik.http.routers.traefik-rtr.rule=Host(`traefik.fructose`)"
- "traefik.http.services.traefik-svc.loadbalancer.server.port=8080"
- default
restart: always
- ./traefik/traefik.toml:/etc/traefik/traefik.toml
- ./traefik/dynamic_conf.toml:/etc/traefik/dynamic_conf.toml
portainer:
container_name: portainer
image: portainer/portainer:latest
labels:
- "traefik.http.routers.portainer-rtr.rule=Host(`portainer.fructose`)"
- "traefik.http.services.portainer-svc.loadbalancer.server.port=9000"
- default
restart: always
- /etc/opt/portainer:/data
adguard:
container_name: adguard
image: adguard/adguardhome:armhf-edge
- "53:53"
- "67:67/udp"
- "68:68/udp"
- "6443:443/tcp"
- "8201:80/tcp"
- "853:853/tcp"
- "3000:3000/tcp"
#labels:
# - "traefik.enable=true"
# - "traefik.http.routers.adguard-rtr.rule=Host(`adguard.fructose`)"
# - "traefik.http.services.adguard-svc.loadbalancer.server.port=80"
network_mode: host
#networks:
# - default
restart: always
- /etc/opt/adguardhome:/opt/adguardhome/conf
- /opt/adguardhome/work:/opt/adguardhome/work
deconz:
image: marthoc/deconz
container_name: deconz
network_mode: host
restart: always
- /opt/deconz:/root/.local/share/dresden-elektronik/deCONZ
devices:
- /dev/ttyACM0
- TZ=Europe/Paris
- DECONZ_WEB_PORT=8600
- DECONZ_WS_PORT=8601
- DEBUG_INFO=0
- DEBUG_APS=0
- DEBUG_ZCL=0
- DEBUG_ZDP=0
- DEBUG_OTAU=0
nodered:
container_name: nodered
image: nodered/node-red:latest
labels:
- "traefik.http.routers.nodered-rtr.rule=Host(`nodered.fructose`)"
- "traefik.http.services.nodered-svc.loadbalancer.server.port=1880"
- default
restart: always
- /etc/opt/nodered:/data
mosquito:
container_name: mosquito
image: eclipse-mosquitto:latest
- default
restart: always
- /etc/opt/mosquitto/mosquito.conf:/mosquito/config/mosquito.conf
grafana:
container_name: grafana
image: grafana/grafana:latest
labels:
- "traefik.http.routers.grafana-rtr.rule=Host(`grafana.fructose`)"
- "traefik.http.services.grafana-svc.loadbalancer.server.port=3000"
- default
restart: always
influxdb:
container_name: influxdb
image: influxdb:latest
- default
homeassistant:
container_name: homeassistant
- TZ=Europe/Paris
image: homeassistant/raspberrypi4-homeassistant
network_mode: host
restart: always
- /etc/opt/homeassistant:/config
No config so far
I want to run some container on my host network.
- adguardhome as I need the dhcp server because of my isp router not allowing dns server selection
(this link explains my problem as it’s the same with pie hole on docker Docker DHCP and Network Modes - Pi-hole documentation) - deconz as it need to communicate with home assistant
- homeassistant as it needs the home network in order to have auto discovery working
I have some other containers which don’t need host network, the bridge would be enough
Could you help me getting a working caddy configuration with like homeassistant on network-mode: host, an other container on bridge and the both of them accessibles throw caddy?
Also I have an other problem regarding docker if any of you have any idea :
Running adguardhome in network_mode: host will make it grab the port 80 for itself and caddy will not be able to use it.
As it’s not possible to map ports when using host mode, I am running out of clues there…
I know I could just add caddy and all my containers to the host network but I would really like to have a clean configuration and to learn how to do things cleanly with caddy as I could use it at work.
Anyhow, I am hopping That my use case is not too specific and that some of the docker experts will have some ideas.
Thank you for the help!
No error as I don’t have a working config
I tried solving my with traefik but I haven’t find anyone running a reverse proxy outside the host network and managing to communicate with the containers connected to the host network
