I can manually run caddy with adjacent Caddyfile, struggling to make any progress with systemctl.
I have set ownership of file to caddy user, and readable by all, caddy seems to read the file and try to solve challenges.
Jan 15 15:57:05 caddy3 systemd[1]: Starting caddy.service - Caddy...
Jan 15 15:57:05 caddy3 caddy[208096]: caddy.HomeDir=/var/lib/caddy
Jan 15 15:57:05 caddy3 caddy[208096]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Jan 15 15:57:05 caddy3 caddy[208096]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Jan 15 15:57:05 caddy3 caddy[208096]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Jan 15 15:57:05 caddy3 caddy[208096]: caddy.Version=v2.7.6 h1:w0NymbG2m9PcvKWsrXO6EEkY9Ru4FJK8uQbYcev1p3A=
Jan 15 15:57:05 caddy3 caddy[208096]: runtime.GOOS=linux
Jan 15 15:57:05 caddy3 caddy[208096]: runtime.GOARCH=amd64
Jan 15 15:57:05 caddy3 caddy[208096]: runtime.Compiler=gc
Jan 15 15:57:05 caddy3 caddy[208096]: runtime.NumCPU=1
Jan 15 15:57:05 caddy3 caddy[208096]: runtime.GOMAXPROCS=1
Jan 15 15:57:05 caddy3 caddy[208096]: runtime.Version=go1.21.5
Jan 15 15:57:05 caddy3 caddy[208096]: os.Getwd=/
Jan 15 15:57:05 caddy3 caddy[208096]: LANG=C
Jan 15 15:57:05 caddy3 caddy[208096]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Jan 15 15:57:05 caddy3 caddy[208096]: NOTIFY_SOCKET=/run/systemd/notify
Jan 15 15:57:05 caddy3 caddy[208096]: HOME=/var/lib/caddy
Jan 15 15:57:05 caddy3 caddy[208096]: LOGNAME=caddy
Jan 15 15:57:05 caddy3 caddy[208096]: USER=caddy
Jan 15 15:57:05 caddy3 caddy[208096]: INVOCATION_ID=f5ded2e93deb4bd8b68ca4006c9b982c
Jan 15 15:57:05 caddy3 caddy[208096]: JOURNAL_STREAM=8:60558778
Jan 15 15:57:05 caddy3 caddy[208096]: SYSTEMD_EXEC_PID=208096
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.299964,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"warn","ts":1705352225.309751,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3137376,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3152032,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3153255,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3155782,"logger":"crowdsec","msg":"Using API key auth","address":"http://localhost:8080/"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3170726,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00095cc80"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.318558,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3188226,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.318953,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.319032,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.319076,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["tautulli.bagin.duckdns.org","jelly.bagin.duckdns.org","sabnzbd.bagin.duckdns.org","homarr.bagin.duckdns.org","kavita.bagin.duckdns.org","prowlarr.bagin.duckdns.org","plex.bagin.duckdns.org","changedetection.bagin.duckdns.org","whisparr.bagin.duckdns.org","portainer.bagin.duckdns.org","adguard.bagin.duckdns.org","nextcloud.bagin.duckdns.org","paperlessngx.bagin.duckdns.org","sonarr.bagin.duckdns.org","bazarr.bagin.duckdns.org","proxmox.bagin.duckdns.org","readarr.bagin.duckdns.org","photoprism.bagin.duckdns.org","vaultwarden.bagin.duckdns.org","kuma.bagin.duckdns.org","overseerr.bagin.duckdns.org","webmin.bagin.duckdns.org","lidarr.bagin.duckdns.org","hass.bagin.duckdns.org","homepage.bagin.duckdns.org","radarr.bagin.duckdns.org"]}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3207953,"logger":"tls.obtain","msg":"acquiring lock","identifier":"tautulli.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3220062,"logger":"tls.obtain","msg":"acquiring lock","identifier":"jelly.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3223019,"logger":"tls.obtain","msg":"lock acquired","identifier":"tautulli.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3224602,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"tautulli.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3234494,"logger":"tls.obtain","msg":"lock acquired","identifier":"jelly.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3235433,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"jelly.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3239777,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["jelly.bagin.duckdns.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"benagin1@gmail.com"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.323991,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["jelly.bagin.duckdns.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"benagin1@gmail.com"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3249164,"logger":"tls.obtain","msg":"acquiring lock","identifier":"sabnzbd.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3253245,"logger":"tls.obtain","msg":"acquiring lock","identifier":"homarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3261669,"logger":"tls.obtain","msg":"acquiring lock","identifier":"prowlarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.326943,"logger":"tls.obtain","msg":"lock acquired","identifier":"homarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3359404,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"homarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.336822,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["homarr.bagin.duckdns.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"benagin1@gmail.com"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.336988,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["homarr.bagin.duckdns.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"benagin1@gmail.com"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3375027,"logger":"tls.obtain","msg":"lock acquired","identifier":"prowlarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3377502,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"prowlarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3382673,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["prowlarr.bagin.duckdns.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"benagin1@gmail.com"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3294563,"logger":"tls.obtain","msg":"acquiring lock","identifier":"sonarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.342013,"logger":"tls.obtain","msg":"lock acquired","identifier":"sonarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3422751,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"sonarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3426101,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["sonarr.bagin.duckdns.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"benagin1@gmail.com"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3314066,"logger":"tls.obtain","msg":"acquiring lock","identifier":"photoprism.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3440504,"logger":"tls.obtain","msg":"lock acquired","identifier":"photoprism.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3444047,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"photoprism.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3448708,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["photoprism.bagin.duckdns.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"benagin1@gmail.com"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3327303,"logger":"tls.obtain","msg":"acquiring lock","identifier":"webmin.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3463795,"logger":"tls.obtain","msg":"lock acquired","identifier":"webmin.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.346748,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"webmin.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3475363,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["webmin.bagin.duckdns.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"benagin1@gmail.com"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3334663,"logger":"tls.obtain","msg":"acquiring lock","identifier":"radarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3495746,"logger":"tls.obtain","msg":"lock acquired","identifier":"radarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.349934,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"radarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3510325,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["radarr.bagin.duckdns.org"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"benagin1@gmail.com"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3356702,"logger":"tls.obtain","msg":"acquiring lock","identifier":"kavita.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3529098,"logger":"tls.obtain","msg":"lock acquired","identifier":"kavita.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3558364,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"kavita.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3270497,"logger":"tls.obtain","msg":"acquiring lock","identifier":"changedetection.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3274179,"logger":"tls.obtain","msg":"acquiring lock","identifier":"whisparr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.327769,"logger":"tls.obtain","msg":"acquiring lock","identifier":"portainer.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.328052,"logger":"tls.obtain","msg":"acquiring lock","identifier":"adguard.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.328334,"logger":"tls.obtain","msg":"acquiring lock","identifier":"nextcloud.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3290362,"logger":"tls.obtain","msg":"acquiring lock","identifier":"paperlessngx.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.3298273,"logger":"tls.obtain","msg":"acquiring lock","identifier":"bazarr.bagin.duckdns.org"}
Jan 15 15:57:05 caddy3 caddy[208096]: {"level":"info","ts":1705352225.330205,"logger":"tls.obtain","msg":"acquiring lock","identifier":"proxmox.bagin.duckdns.org"}
this is my most recent run with debug enabled
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2228067,"logger":"events","msg":"event","name":"tls_get_certificate","id":"4fa3edec-c039-40fb-87fe-00f57e3903af","origin":"tls","data":{"client_hello":{"CipherSuites":[51914,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"readarr.bagin.duckdns.org","SupportedCurves":[39578,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[31354,772,771],"RemoteAddr":{"IP":"74.215.78.143","Port":51671,"Zone":""},"LocalAddr":{"IP":"192.168.4.136","Port":443,"Zone":""}}}}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.225732,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"readarr.bagin.duckdns.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2257676,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.bagin.duckdns.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2257836,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.duckdns.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2257988,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2258139,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.*"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2258356,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"74.215.78.143","remote_port":"51671","server_name":"readarr.bagin.duckdns.org","remote":"74.215.78.143:51671","identifier":"readarr.bagin.duckdns.org","cipher_suites":[51914,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2259252,"logger":"http.stdlib","msg":"http: TLS handshake error from 74.215.78.143:51671: no certificate available for 'readarr.bagin.duckdns.org'"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2269459,"logger":"http.stdlib","msg":"http: TLS handshake error from 74.215.78.143:51670: no certificate available for 'radarr.bagin.duckdns.org'"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.263778,"logger":"events","msg":"event","name":"tls_get_certificate","id":"0cea10e1-1c61-4100-b1c8-9076a2186680","origin":"tls","data":{"client_hello":{"CipherSuites":[27242,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"radarr.bagin.duckdns.org","SupportedCurves":[56026,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[35466,772,771],"RemoteAddr":{"IP":"74.215.78.143","Port":51672,"Zone":""},"LocalAddr":{"IP":"192.168.4.136","Port":443,"Zone":""}}}}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2639751,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"radarr.bagin.duckdns.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2639995,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.bagin.duckdns.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2640152,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.duckdns.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2640295,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2640445,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.*"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.26407,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"74.215.78.143","remote_port":"51672","server_name":"radarr.bagin.duckdns.org","remote":"74.215.78.143:51672","identifier":"radarr.bagin.duckdns.org","cipher_suites":[27242,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.264297,"logger":"http.stdlib","msg":"http: TLS handshake error from 74.215.78.143:51672: no certificate available for 'radarr.bagin.duckdns.org'"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.265513,"logger":"events","msg":"event","name":"tls_get_certificate","id":"bcfe1ced-a359-4451-835f-c05d73be35bb","origin":"tls","data":{"client_hello":{"CipherSuites":[23130,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"readarr.bagin.duckdns.org","SupportedCurves":[23130,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[31354,772,771],"RemoteAddr":{"IP":"74.215.78.143","Port":51673,"Zone":""},"LocalAddr":{"IP":"192.168.4.136","Port":443,"Zone":""}}}}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.265622,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"readarr.bagin.duckdns.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2656424,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.bagin.duckdns.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2656581,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.duckdns.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.265676,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.org"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2656908,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.*"}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.2657118,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"74.215.78.143","remote_port":"51673","server_name":"readarr.bagin.duckdns.org","remote":"74.215.78.143:51673","identifier":"readarr.bagin.duckdns.org","cipher_suites":[23130,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
Jan 15 18:50:18 caddy3 caddy[163]: {"level":"debug","ts":1705362618.265793,"logger":"http.stdlib","msg":"http: TLS handshake error from 74.215.78.143:51673: no certificate available for 'readarr.bagin.duckdns.org'"}
Jan 15 18:50:19 caddy3 caddy[163]: {"level":"debug","ts":1705362619.4077406,"logger":"tls.issuance.zerossl.acme_client","msg":"http request","method":"HEAD","url":"https://acme.zerossl.com/v2/DV90/newNonce","headers":{"User-Agent":["Caddy/2.7.6 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Type":["application/octet-stream"],"Date":["Mon, 15 Jan 2024 23:50:19 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["SmTfSqweCB5lVnKV9LkGqPc7YoHp9kTCMgaRT1plEFo"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]},"status_code":200}
Jan 15 18:50:21 caddy3 caddy[163]: {"level":"error","ts":1705362621.5928197,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"readarr.bagin.duckdns.org","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.readarr.bagin.duckdns.org\" (usually OK if presenting also failed)"}
Jan 15 18:50:21 caddy3 caddy[163]: {"level":"debug","ts":1705362621.7069635,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/10633795364","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["132394644"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["834"],"Content-Type":["application/json"],"Date":["Mon, 15 Jan 2024 23:50:21 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["Jarfjukg0FIdHUHAYSPZZ9GQH0oFX4oYzJcUfkjtsTtuplyRAdc"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
Jan 15 18:50:21 caddy3 caddy[163]: {"level":"error","ts":1705362621.707349,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"readarr.bagin.duckdns.org","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[readarr.bagin.duckdns.org] solving challenges: presenting for challenge: could not determine zone for domain \"_acme-challenge.readarr.bagin.duckdns.org\": unexpected response code 'SERVFAIL' for _acme-challenge.readarr.bagin.duckdns.org. (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/132394644/13704613724) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jan 15 18:50:21 caddy3 caddy[163]: {"level":"debug","ts":1705362621.707403,"logger":"tls.obtain","msg":"trying issuer 2/2","issuer":"acme.zerossl.com-v2-DV90"}
Jan 15 18:50:21 caddy3 caddy[163]: {"level":"debug","ts":1705362621.9558177,"logger":"tls.issuance.zerossl.acme_client","msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/newOrder","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.7.6 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Length":["286"],"Content-Type":["application/json"],"Date":["Mon, 15 Jan 2024 23:50:21 GMT"],"Location":["https://acme.zerossl.com/v2/DV90/order/p-ns9uSC2WRzqN7-VOgWDw"],"Replay-Nonce":["8_Xy2JJQuc8_ayCwhEobDuFUzWUW6Mmr6x3iVAsyuJQ"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]},"status_code":201}
with crowdsec and duckdns plugins
xcaddy build with plugins above, did steps to move to /bin(?). I setup caddy service for systemctl with caddy user etc
up to date proxmox debian container, all versions new within the month
caddy start
systemctl start caddy
manual version works, systemctl gives no errors but does not work
my caddy.service file:
# caddy.service
# for your installation.
Type=notify
GNU nano 7.2 Caddyfile
# debug # this is optional; makes Caddy log more details
order crowdsec first
crowdsec {
api_url http://localhost:8080 # the URL where your CrowdSec LAPI can be reached
api_key __KEY__
email __EMAIL__
## imports:
(crowdsec) {
crowdsec
(duckdns) {
dns duckdns __KEY__ {
override_domain bagin.duckdns.org
(notHomeIp) {
@notHomeIp {
not remote_ip __ADDRESS__
respond @notHomeIp 403
## reverse proxies:
kavita.bagin.duckdns.org {
import crowdsec
import duckdns
import notHomeIp
reverse_proxy __ADDRESS__
proxmox.bagin.duckdns.org {
import crowdsec
import duckdns
import notHomeIp
reverse_proxy __ADDRESS__ {
tls_trusted_ca_certs /etc/pve/pve-root-ca.pem # Path to PVE root cert
sabnzbd.bagin.duckdns.org {
import crowdsec
import duckdns
import notHomeIp
(continued...)
