Configuring reverse proxy to portainer
v2.4.6
Ubuntu 20.04.4 LTS
docker-compose up -d
version: "3.7"
  plex:
    container_name: plex
      - internal
      - PUID=1000
      - PGID=1000
      - VERSION=docker
      - plex_data:/config
      - /mnt/unionfs:/media
    restart: always
    image: linuxserver/plex:latest
  portainer:
    container_name: portainer
    image: portainer/portainer-ce:latest
    command: -H unix:///var/run/docker.sock
    restart: always
      - VIRTUAL_HOST=portainer.24-7tv.com
      - VIRTUAL_PORT=9443
      - portainer_data:/data
      - internal
    image: jmricker/caddy-cloudflare:latest
      ACME_AGREE: 'true'
      CLOUDFLARE_EMAIL: 'my@email'
      CLOUDFLARE_API_TOKEN: '1M7UxRa1KDGdqqxk8yw65x2xJ2JMsYEr4i'
      DOMAIN: '24-7tv.com'
      - /opt/appdata/superplex/caddy/Caddyfile:/etc/caddy/Caddyfile
      - /opt/appdata/superplex/caddy/data:/data
      - /opt/appdata/superplex/caddy/config:/config
      - web
      - internal
  web:
    external: true
  internal:
    external: false
    driver: bridge
  portainer_data:
  plex_data:
    email my@email
portainer.24-7tv.com {
   reverse_proxy portainer:9443
   #reverse_proxy portainer:9000
          dns cloudflare 1M7UxRa1KDGdqqxk8yw65x2xJ2JMsYEr4i
plex.24-7tv.com {
   reverse_proxy plex:32400
I’ve been able to get Caddy setup on my remote server as a reverse proxy. I’m using docker to manage all of my containers with a Portainer frontend. I’ve got this mostly working but had an issue and a few questions that I couldn’t quite find a resolution on.
The first issue to do with Portainer. Port 9443 is the current port for use by Portainer. However with my setup, I get this message “Client sent an HTTP request to an HTTPS server.” From what I can see from the wget, it changes to the request to HTTPS so I’m not sure what client is making the HTTP request. As a fix, what I can do is change the port to 9000 (reverse_proxy portainer:9000). As far as I know that technically works the problem is that the 9000 port is deprecated and I imagine will eventually go away so I would like to get this pointed to the correct port.
Second question is on 404, or error pages. So if I there is a invalid subdomain, such as test.24-7tv.com, right now the site gives back a 525 error message, SSL Handshake Failed. Is there a good way create a catch all to reroute this to a 404 page?
Thanks!
$ wget -v portainer.24-7tv.com
URL transformed to HTTPS due to an HSTS policy
--2022-03-28 20:23:38--  https://portainer.24-7tv.com/
Resolving portainer.24-7tv.com (portainer.24-7tv.com)... 2606:4700:3034::ac43:b4b8, 2606:4700:3037::6815:1fe5, 172.67.180.184, ...
Connecting to portainer.24-7tv.com (portainer.24-7tv.com)|2606:4700:3034::ac43:b4b8|:443... connected.
HTTP request sent, awaiting response... 400 Bad Request
2022-03-28 20:23:39 ERROR 400: Bad Request.
You will have to create a wildcard host entry and use route handler.
Caddy expects you to be explicit about your subdomains as a good practice
There’s an example in the docs for this:
Also, I really hope you didn’t just paste your actual cloudflare key on the forums
:grimacing:
You’ll need to revoke that key and get a new one.
Hah! No its not. Actually its a fake bitcoin address generated by Mockaroo. I guess it looks a bit too much like a real key doesn’t it? Maybe someone will get a kick from trying to use it.
Aww, that foils my $1 unlimited CF DNS updates business plans :frowning:
