Configuring Multi-Pod Caddy Deployment on GKE for HTTP-01 Challenges
I’m facing an issue running Caddy on GKE with a shared NFS volume in read-write many mode. Here’s a detailed description of the setup and the problem I’m encountering:
I’m deploying Caddy for a High Availability (HA) configuration with multiple (10) pods. The goal is to provision customer’s white-label domains using Caddy’s configuration capabilities and leverage the automatic HTTPS feature with the ask endpoint. Zero SSL is my certificate provider.
Clients using these white-label domains create CNAME records pointing to Caddy’s host domain (eg: awesome.customer.comcname.exmple-caddy.com), enabling HTTP-01 challenges. However, since Caddy dynamically listens on port 80 for these challenges, only one pod out of the ten running can handle the request at a time. If the challenge gets routed to a different pod (port 80 not open), the challenge fails, and certificate provisioning fails as well.
More of a general question, I’m not sure if logs are relevant here. I can add it if they are needed.
Installed Caddy on Kubernetes, below is the configuration used for Caddy. K8s config can be found in 4c.
  "logging": {
    "logs": {
      "default": {
        "level": "DEBUG"
  "apps": {
    "http": {
      "servers": {
        "srv0": {
          "listen": [":443"],
          "routes": [{
            "handle": [{
              "handler": "reverse_proxy",
              "upstreams": [{
                "dial": "app.mycompany.com:443"
              "transport": {
                "protocol": "http",
                "tls": {}
          "automatic_https": {
            "disable_redirects": true
          "max_header_bytes": 4096,
          "read_header_timeout": "10s",
          "read_timeout": "10s",
          "write_timeout": "10s",
          "idle_timeout": "1m"
    "tls": {
      "automation": {
        "on_demand": {
          "ask": "https://mock.httpstatus.io/200"
        "policies": [
            "on_demand": true,
            "issuers": [
                "module": "zerossl",
                "api_key": "<redacted>"
Kubernetes on GKE: 1.27.11-gke.1062004
caddy run --config /etc/caddy/caddy.json
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
  namespace: default
spec:
  accessModes:
    - ReadWriteMany
  resources:
    requests:
      storage: 10Gi
  storageClassName: standard-rwx
apiVersion: v1
metadata:
  namespace: default
spec:
  accessModes:
    - ReadWriteMany
  resources:
    requests:
      storage: 1Gi
apiVersion: v1
kind: ConfigMap
metadata:
  namespace: default
data:
  caddy.json: |
      "logging": {
        "logs": {
          "default": {
            "level": "DEBUG"
      "apps": {
        "http": {
          "servers": {
            "srv0": {
              "listen": [":443"],
              "routes": [{
                "handle": [{
                  "upstreams": [{
                  "transport": {
                    "protocol": "http",
                    "tls": {}
        "tls": {
          "automation": {
            "on_demand": {
            "policies": [
                "on_demand": true,
                "issuers": [
apiVersion: apps/v1
kind: Deployment
metadata:
  namespace: default
spec:
  replicas: 10
  selector:
    matchLabels:
      app: caddy
  template:
    metadata:
      labels:
        app: caddy
    spec:
      containers:
      - name: caddy
        command: ["caddy", "run", "--config", "/etc/caddy/caddy.json"]
        image: caddy:2.7.6
        - containerPort: 443
        - containerPort: 80
        volumeMounts:
        - name: caddy-config
          mountPath: /etc/caddy/caddy.json
          subPath: caddy.json
        - name: caddy-data
          mountPath: /data
        - name: caddy-config-dir
          mountPath: /config
        configMap:
      - name: caddy-data
        persistentVolumeClaim:
          claimName: caddy-data-pvc
          claimName: caddy-config-pvc
apiVersion: v1
kind: Service
metadata:
  namespace: default
spec:
  type: LoadBalancer
  selector:
    app: caddy
  - protocol: TCP
    port: 443
    targetPort: 443
  - protocol: TCP
    port: 80
    targetPort: 80
Please use the latest version, v2.8.4
You must configure all your Caddy instances to share storage. Caddy can coordinate with the rest of the cluster through the storage, using entries in the storage as locks for other instances to recognize. See Automatic HTTPS — Caddy Documentation
Hi @francislavoie, thank you for your response.
Following your advice, I installed Caddy version 2.8.4 and created a shared volume for the home directory (which is /root in my setup), in addition to the data and config volumes I already had shared across multiple Caddy instances.
I am conducting load tests with both a single instance and multiple instances of Caddy to ensure everything functions correctly with 10 pods. Despite this setup, when running just 2 instances, I encounter inconsistencies with certificate generation that do not occur with a single instance. I have triple-checked the volume mounts, and they appear to be configured correctly.
Attached below are the logs from the two pods, which indicate that certificate provisioning fails due to an HTTP 01 challenge failure. Could you help me understand what might be causing this issue?
Please note that example.io is a fake domain and I have no issues generating certs with only a single instance of Caddy running.
Logs from 1st instance
{"level":"debug","ts":1718748229.3288038,"logger":"events","msg":"event","name":"tls_get_certificate","id":"aa31e8af-a6cf-4c24-9eb9-24b5bba678dd","origin":"tls","data":{"client_hello":{"CipherSuites":[56026,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"test-150.example.io","SupportedCurves":[51914,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[23130,772,771],"RemoteAddr":{"IP":"10.142.0.37","Port":23858,"Zone":""},"LocalAddr":{"IP":"10.100.43.60","Port":443,"Zone":""}}}}
{"level":"debug","ts":1718748229.328903,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"test-150.example.io"}
{"level":"debug","ts":1718748229.3289223,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.example.io"}
{"level":"debug","ts":1718748229.3289258,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.io"}
{"level":"debug","ts":1718748229.3289292,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*"}
{"level":"debug","ts":1718748229.3289466,"logger":"tls.handshake","msg":"all external certificate managers yielded no certificates and no errors","remote_ip":"10.142.0.37","remote_port":"23858","sni":"test-150.example.io"}
{"level":"debug","ts":1718748229.3289578,"logger":"tls","msg":"asking for permission for on-demand certificate","remote_ip":"10.142.0.37","domain":"test-150.example.io"}
{"level":"debug","ts":1718748229.3289871,"logger":"tls","msg":"asking permission endpoint","remote":"10.142.0.37:23858","domain":"test-150.example.io","url":"https://mock.httpstatus.io/200?domain=test-150.example.io"}
{"level":"debug","ts":1718748229.5971868,"logger":"tls","msg":"response from permission endpoint","remote":"10.142.0.37:23858","domain":"test-150.example.io","url":"https://mock.httpstatus.io/200?domain=test-150.example.io","status":200}
{"level":"debug","ts":1718748229.6456945,"logger":"tls.handshake","msg":"did not load cert from storage","remote_ip":"10.142.0.37","remote_port":"23858","server_name":"test-150.example.io","error":"no matching certificate to load for test-150.example.io: open /data/caddy/certificates/zerossl/wildcard_.example.io/wildcard_.example.io.key: no such file or directory"}
{"level":"info","ts":1718748229.6457565,"logger":"tls.on_demand","msg":"obtaining new certificate","remote_ip":"10.142.0.37","remote_port":"23858","server_name":"test-150.example.io"}
{"level":"info","ts":1718748229.746155,"logger":"tls.obtain","msg":"acquiring lock","identifier":"test-150.example.io"}
{"level":"debug","ts":1718748260.445699,"logger":"events","msg":"event","name":"tls_get_certificate","id":"5d39f6a0-f156-4ca9-a572-8f5cb4a71e2e","origin":"tls","data":{"client_hello":{"CipherSuites":[43690,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"test-150.example.io","SupportedCurves":[64250,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[60138,772,771],"RemoteAddr":{"IP":"10.142.0.82","Port":36287,"Zone":""},"LocalAddr":{"IP":"10.100.43.60","Port":443,"Zone":""}}}}
{"level":"debug","ts":1718748260.4457433,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"test-150.example.io"}
{"level":"debug","ts":1718748260.4457526,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.example.io"}
{"level":"debug","ts":1718748260.4457557,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.io"}
{"level":"debug","ts":1718748260.4457579,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*"}
Logs from 2nd instance
{"level":"debug","ts":1718748229.5923295,"logger":"tls.handshake","msg":"did not load cert from storage","remote_ip":"10.142.0.152","remote_port":"21391","server_name":"test-150.example.io","error":"no matching certificate to load for test-150.example.io: open /data/caddy/certificates/zerossl/wildcard_.example.io/wildcard_.example.io.key: no such file or directory"}
{"level":"info","ts":1718748229.5923765,"logger":"tls.on_demand","msg":"obtaining new certificate","remote_ip":"10.142.0.152","remote_port":"21391","server_name":"test-150.example.io"}
{"level":"info","ts":1718748229.7273417,"logger":"tls.obtain","msg":"acquiring lock","identifier":"test-150.example.io"}
{"level":"info","ts":1718748229.7499487,"logger":"tls.obtain","msg":"lock acquired","identifier":"test-150.example.io"}
{"level":"info","ts":1718748229.7505078,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"test-150.example.io"}
{"level":"debug","ts":1718748229.7505803,"logger":"events","msg":"event","name":"cert_obtaining","id":"60e426a5-93de-4dc7-99da-dce014009d56","origin":"tls","data":{"identifier":"test-150.example.io"}}
{"level":"debug","ts":1718748229.7512107,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"zerossl"}
{"level":"info","ts":1718748229.7513769,"logger":"tls.issuance.zerossl","msg":"creating certificate","identifiers":["test-150.example.io"]}
{"level":"info","ts":1718748231.6271038,"logger":"tls.issuance.zerossl","msg":"created certificate","identifiers":["test-150.example.io"],"cert_id":"1fddb9240c3fde28e4edb0e078d1a974"}
{"level":"info","ts":1718748231.633594,"logger":"tls.issuance.zerossl","msg":"validating identifiers","identifiers":["test-150.example.io"],"cert_id":"1fddb9240c3fde28e4edb0e078d1a974","verification_method":"HTTP_CSR_HASH"}
{"level":"info","ts":1718748232.2369077,"logger":"tls.issuance.zerossl","msg":"canceled certificate","identifiers":["test-150.example.io"],"cert_id":"1fddb9240c3fde28e4edb0e078d1a974","verification_method":"HTTP_CSR_HASH"}
{"level":"error","ts":1718748232.2369719,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"test-150.example.io","issuer":"zerossl","error":"verifying identifiers: POST https://api.zerossl.com/certificates/1fddb9240c3fde28e4edb0e078d1a974/challenges?access_key=redacted: HTTP 200: API error 0: domain_control_validation_failed (details=map[test-150.example.io:map[http://test-150.example.io/.well-known/pki-validation/4688054CE4FCE733C9852EC326D095C3.txt:{{0 0 } {0 true http_transport_failed Error: HTTP transport exception in file validation. Check if your server and the validation file are reachable and maybe retry afterwards?}}]]) (raw={\"success\":false,\"error\":{\"code\":0,\"type\":\"domain_control_validation_failed\",\"details\":{\"test-150.example.io\":{\"http:\\/\\/test-150.example.io\\/.well-known\\/pki-validation\\/4688054CE4FCE733C9852EC326D095C3.txt\":{\"file_found\":0,\"error\":true,\"error_slug\":\"http_transport_failed\",\"error_info\":\"Error: HTTP transport exception in file validation. Check if your server and the validation file are reachable and maybe retry afterwards?\"}}}}} decode_error=json: unknown field \"success\")"}
{"level":"debug","ts":1718748232.2370641,"logger":"events","msg":"event","name":"cert_failed","id":"edd16c96-b7c1-4d7a-9a17-440044e456a4","origin":"tls","data":{"error":{},"identifier":"test-150.example.io","issuers":["zerossl"],"renewal":false}}
{"level":"error","ts":1718748232.2371006,"logger":"tls.obtain","msg":"will retry","error":"[test-150.example.io] Obtain: verifying identifiers: POST https://api.zerossl.com/certificates/1fddb9240c3fde28e4edb0e078d1a974/challenges?access_key=redacted: HTTP 200: API error 0: domain_control_validation_failed (details=map[test-150.example.io:map[http://test-150.example.io/.well-known/pki-validation/4688054CE4FCE733C9852EC326D095C3.txt:{{0 0 } {0 true http_transport_failed Error: HTTP transport exception in file validation. Check if your server and the validation file are reachable and maybe retry afterwards?}}]]) (raw={\"success\":false,\"error\":{\"code\":0,\"type\":\"domain_control_validation_failed\",\"details\":{\"test-150.example.io\":{\"http:\\/\\/test-150.example.io\\/.well-known\\/pki-validation\\/4688054CE4FCE733C9852EC326D095C3.txt\":{\"file_found\":0,\"error\":true,\"error_slug\":\"http_transport_failed\",\"error_info\":\"Error: HTTP transport exception in file validation. Check if your server and the validation file are reachable and maybe retry afterwards?\"}}}}} decode_error=json: unknown field \"success\")","attempt":1,"retrying_in":60,"elapsed":2.487114281,"max_duration":2592000}
{"level":"debug","ts":1718748260.4458015,"logger":"events","msg":"event","name":"tls_get_certificate","id":"a82a219a-3193-4d06-a026-05dd1b772b4d","origin":"tls","data":{"client_hello":{"CipherSuites":[2570,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"test-150.example.io","SupportedCurves":[19018,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[56026,772,771],"RemoteAddr":{"IP":"10.142.0.127","Port":58667,"Zone":""},"LocalAddr":{"IP":"10.100.52.160","Port":443,"Zone":""}}}}
{"level":"debug","ts":1718748260.4458406,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"test-150.example.io"}
{"level":"debug","ts":1718748260.4458485,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.example.io"}
{"level":"debug","ts":1718748260.4458528,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.io"}
{"level":"debug","ts":1718748260.4458563,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*"}
{"level":"info","ts":1718748292.23929,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"test-150.example.io"}
{"level":"debug","ts":1718748292.239399,"logger":"events","msg":"event","name":"cert_obtaining","id":"83cb1a1a-b481-40e1-9526-6c18c0e3257c","origin":"tls","data":{"identifier":"test-150.example.io"}}
{"level":"debug","ts":1718748292.239748,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"zerossl"}
{"level":"info","ts":1718748292.2398481,"logger":"tls.issuance.zerossl","msg":"creating certificate","identifiers":["test-150.example.io"]}
{"level":"info","ts":1718748293.34797,"logger":"tls.issuance.zerossl","msg":"created certificate","identifiers":["test-150.example.io"],"cert_id":"a35da5dad6db5601ae040c14b0e72406"}
{"level":"info","ts":1718748293.35398,"logger":"tls.issuance.zerossl","msg":"validating identifiers","identifiers":["test-150.example.io"],"cert_id":"a35da5dad6db5601ae040c14b0e72406","verification_method":"HTTP_CSR_HASH"}
{"level":"info","ts":1718748293.7028039,"logger":"tls.issuance.zerossl","msg":"canceled certificate","identifiers":["test-150.example.io"],"cert_id":"a35da5dad6db5601ae040c14b0e72406","verification_method":"HTTP_CSR_HASH"}
{"level":"error","ts":1718748293.702842,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"test-150.example.io","issuer":"zerossl","error":"verifying identifiers: POST https://api.zerossl.com/certificates/a35da5dad6db5601ae040c14b0e72406/challenges?access_key=redacted: HTTP 200: API error 0: domain_control_validation_failed (details=map[test-150.example.io:map[http://test-150.example.io/.well-known/pki-validation/4122810758B64FF77BF703BE87856D87.txt:{{0 0 } {0 true http_transport_failed Error: HTTP transport exception in file validation. Check if your server and the validation file are reachable and maybe retry afterwards?}}]]) (raw={\"success\":false,\"error\":{\"code\":0,\"type\":\"domain_control_validation_failed\",\"details\":{\"test-150.example.io\":{\"http:\\/\\/test-150.example.io\\/.well-known\\/pki-validation\\/4122810758B64FF77BF703BE87856D87.txt\":{\"file_found\":0,\"error\":true,\"error_slug\":\"http_transport_failed\",\"error_info\":\"Error: HTTP transport exception in file validation. Check if your server and the validation file are reachable and maybe retry afterwards?\"}}}}} decode_error=json: unknown field \"success\")"}
{"level":"debug","ts":1718748293.702901,"logger":"events","msg":"event","name":"cert_failed","id":"810e0779-1a03-4e54-a5aa-cac78f0db072","origin":"tls","data":{"error":{},"identifier":"test-150.example.io","issuers":["zerossl"],"renewal":false}}
{"level":"error","ts":1718748293.7029192,"logger":"tls.obtain","msg":"will retry","error":"[test-150.example.io] Obtain: verifying identifiers: POST https://api.zerossl.com/certificates/a35da5dad6db5601ae040c14b0e72406/challenges?access_key=redacted: HTTP 200: API error 0: domain_control_validation_failed (details=map[test-150.example.io:map[http://test-150.example.io/.well-known/pki-validation/4122810758B64FF77BF703BE87856D87.txt:{{0 0 } {0 true http_transport_failed Error: HTTP transport exception in file validation. Check if your server and the validation file are reachable and maybe retry afterwards?}}]]) (raw={\"success\":false,\"error\":{\"code\":0,\"type\":\"domain_control_validation_failed\",\"details\":{\"test-150.example.io\":{\"http:\\/\\/test-150.example.io\\/.well-known\\/pki-validation\\/4122810758B64FF77BF703BE87856D87.txt\":{\"file_found\":0,\"error\":true,\"error_slug\":\"http_transport_failed\",\"error_info\":\"Error: HTTP transport exception in file validation. Check if your server and the validation file are reachable and maybe retry afterwards?\"}}}}} decode_error=json: unknown field \"success\")","attempt":2,"retrying_in":120,"elapsed":63.952933847,"max_duration":2592000}
Here is my updated config for Caddy + GKE setup:
apiVersion: v1
metadata:
  namespace: default
spec:
  accessModes:
    - ReadWriteMany
  resources:
    requests:
      storage: 5Gi
apiVersion: v1
metadata:
  namespace: default
spec:
  accessModes:
    - ReadWriteMany
  resources:
    requests:
      storage: 10Gi
apiVersion: v1
metadata:
  namespace: default
spec:
  accessModes:
    - ReadWriteMany
  resources:
    requests:
      storage: 1Gi
apiVersion: v1
kind: ConfigMap
metadata:
  namespace: default
data:
  caddy.json: |
      "logging": {
        "logs": {
          "default": {
            "level": "DEBUG"
      "apps": {
        "http": {
          "servers": {
            "srv0": {
              "listen": [":443"],
              "routes": [{
                "handle": [{
                  "upstreams": [{
                  "transport": {
                    "protocol": "http",
                    "tls": {}
        "tls": {
          "automation": {
            "on_demand": {
            "policies": [
                "on_demand": true,
                "issuers": [
apiVersion: apps/v1
kind: Deployment
metadata:
  namespace: default
spec:
  replicas: 2
  selector:
    matchLabels:
      app: caddy
  template:
    metadata:
      labels:
        app: caddy
    spec:
      containers:
      - name: caddy
        image: caddy:2.8.4
        - containerPort: 80
        volumeMounts:
          subPath: caddy.json
        - name: caddy-data
          mountPath: /data
          mountPath: /config
        - name: caddy-home-dir
          mountPath: /root
        configMap:
      - name: caddy-data
          claimName: caddy-home-pvc
apiVersion: v1
kind: Service
metadata:
  namespace: default
spec:
  type: LoadBalancer
  selector:
    app: caddy
  - protocol: TCP
    port: 443
    targetPort: 443
  - protocol: TCP
    port: 80
    targetPort: 80
Looks like ZeroSSL isn’t able to reach your server. It must be somekind of networking issue. Are you sure your server is publicly accessible on port 80?
Caddy stores its data in /data when running in Docker, not /root. Are you sure that’s correct?
If you’re going to be using k8s, shouldn’t you use somekind of distributed storage, not the filesystem? You can build Caddy with a Redis storage plugin for example, and use that to store your certs.
Yes, I am completely certain that port 80 is open on the Google Load Balancer. However, Caddy does not listen on this port until the HTTP 01 challenge is initiated. Additionally, ZeroSSL successfully connects to the server when I use a single instance of Caddy. For my load tests with multiple instances, I scale my singleton deployment to 2 replicas, but keep the server IP and DNS unchanged.
Caddy stores its data in /data when running in Docker, not /root . Are you sure that’s correct?
I have shared the /data, /config, and /root volumes across all pods, which should cover all possible scenarios. Furthermore, I have verified that both the certificates (located in the ZeroSSL folder) and the configuration files are present in the /data and /config directories.
While I could implement the Redis plugin, using a shared NFS volume seemed more advantageous to me, as it allows for GCP managed backups, among other benefits such as eliminating the need to set up monitoring and alerting for Redis. However, do you see any issues with using a volume mount in GKE, or is this approach generally acceptable?
I believe this is my issue. Since Caddy dynamically listens on port 80 for the HTTP 01 challenge, it’s possible that only one of the pods is prepared to handle the request. If the challenge gets routed to another pod where port 80 isn’t open, the challenge will fail, leading to unsuccessful certificate provisioning.
That’s not true, Caddy listens on port 80 as soon as it starts, if the config qualifies for Automatic HTTPS (your logs will mention this on startup).
I’ve never used k8s nor Google Cloud so I can’t say. NFS can generally work fine but writes are not atomic (writes don’t block until everyone sees the file) so there’s a chance for the locks to not get propagated before another instance picks up the request.
I’m not 100% sure what this means, because ZeroSSL API support is brand new in v2.8.0 and I’ve not played with it enough myself or seen enough questions on the forums about this yet, but to me HTTP transport exception in file validation sounds like a networking problem (i.e. failed to connect to Caddy) and not a 404 (failed to find the ACME HTTP file in storage to serve).
i’ve actually disabled automatic redirect. See the startup logs for Caddy below
{"level":"info","ts":1718758805.649295,"msg":"using config from file","file":"/etc/caddy/caddy.json"}
{"level":"info","ts":1718758805.652366,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1718758805.6533315,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1718758805.6534061,"logger":"http.auto_https","msg":"automatic HTTP->HTTPS redirects are disabled","server_name":"srv0"}
i had it enabled in the past and i thought that was causing HTTP 01 challenge failures so i’ve disabled it until i figure out why things are not working as expected.
I made some calls to my endpoint to show that port 80 is disabled.
nc -vz test-150.example.io 443
Connection to test-150.example.io port 443 [tcp/https] succeeded!
nc -vz test-150.example.io 80
nc: connectx to test-150.example.io port 80 (tcp) failed: Connection refused
I suspected port 80 being closed is the issue so I used the config below with Caddy and that greatly reduced the number of errors I was getting with my load test.
  "logging": {
    "logs": {
      "default": {
        "level": "DEBUG"
  "apps": {
    "http": {
      "servers": {
        "srv0": {
          "listen": [":443"],
          "routes": [{
            "handle": [{
              "upstreams": [{
              "transport": {
                "protocol": "http",
                "tls": {}
        "srv1": {
          "listen": [":80"],
          "routes": [{
            "handle": [{
              "upstreams": [{
                "dial": "google.com:443"
    "tls": {
      "automation": {
        "on_demand": {
        "policies": [
            "on_demand": true,
            "issuers": [
I see, yea this could be causing the issues I’m having but I feel there is more to it.
I got it to work, it seems automatic redirects must be enabled for my setup to work properly
Hmm, that doesn’t sound right.
CertMagic should open a port 80 to solve HTTP challenges if it’s not in use.
Did you check for port 80 being used when the HTTP challenge was initiated? It will open the port and then close it after the challenge fails or succeeds.
Ah, that explains it then. I had no idea that was the behaviour. I think that’s a bad default, it should be changed.
In this case because clustering is involved, that behaviour is not good because then only the instance that initiates issuance will be listening for the challenge, then close after.
@New_user_AA why were you turning off redirects anyway? They’re a good thing to have on anyway.
I am quite sure this occurred because I monitored netstat -tulpn on both pods side by side. The first pod had port 80 open temporarily (presumably for the HTTP 01 challenge) and then closed, while the second pod did not open port 80 at all.
It was accidental. I was adjusting the JSON configuration and must have disabled redirects while troubleshooting a different error. Since I re-enabled it, everything has been working smoothly.
