Configuring http for forwarding traffic
Hi,
How to configure http for forward traffic. Similar to nginx, for example:
# NGINX vhost block example
location = /$PATH {
        proxy_pass http://127.0.0.1:15000;
        proxy_http_version 1.1;
        ### Set WebSocket headers ###
        proxy_set_header Connection "upgrade";
        ### Set Proxy headers ###
        proxy_set_header        Accept-Encoding   "";
        proxy_set_header        Host            $host;
        proxy_set_header        X-Real-IP       $remote_addr;
        proxy_set_header        X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header        X-Forwarded-Proto $scheme;
        add_header              Front-End-Https   on;
        proxy_redirect     off;
        access_log  off;
        error_log off;
Thanks, Jacobo
With caddy you can simply do this
domain.com {
    reverse_proxy 127.0.0.1:15000
The headers and such are all set automatically by default.
Or
domain.com {
    reverse_proxy /somepath* 127.0.0.1:15000
Be careful with recommending that. Path matchers are exact, so this would only match /somepath and nothing else.
Also if you match a subpath, you should have some other handler to handle otherwise unmatched requests.
Noted. Edited post for wildcard. In my case I use the absolute path matcher for public access so as to control it in a more meticulous way.
Thanks @victor @francislavoie. In my case, I am looking for it to be a strict path
