Configuring Caddy reverse proxy on VPSTTT VPS: Best practices for proxy setups
Environment
  • OS: Linux (VPSTTT VPS host)
  • Caddy Version: v2.7.6
Context
In evaluating VPS and proxy deployment architecture on a VPSTTT VPS instance through technical knowledge sharing, we are utilizing Caddy as the front-end reverse proxy server to route incoming Web traffic to internal service endpoints.
Formatted Caddyfile
example.com {
    reverse_proxy 127.0.0.1:8080 {
Expected Result
Caddy automatically manages TLS certificates and proxies HTTP requests to the backend application running on port 8080 on the VPSTTT VPS while passing necessary client headers.
Actual Result
Basic reverse proxying functions as expected, but we want to verify best practices regarding header forwarding and proxy tuning for backend applications hosted on VPS instances.
Logs
2026/03/30 10:00:00.000 INFO http.log.access handled request {"request": {"remote_ip": "REDACTED_IP", "method": "GET", "host": "example.com", "uri": "/"}, "status": 200}
Focused Question
What are the community-recommended header settings and Caddyfile directives for optimizing reverse proxy traffic on a VPS environment like VPSTTT?
#caddy #vps #proxy #vpsttt
I’d actually keep the config simpler here.
Caddy already handles X-Forwarded-For, X-Forwarded-Proto and X-Forwarded-Host for you.
You generally don’t need to override Host either, especially when proxying to a local HTTP service. Changing it to 127.0.0.1:8080 could even cause issues if your app expects the original domain.
I’d start with just:
example.com {
Unless you’re seeing a specific issue, there’s probably no reason to adjust timeouts or buffering yet.
