Configure caddy with BigIP
v2.1.0-beta.1 h1:nG+Y2NuoqGvJEnHlVO5PXtTxuc2yHsjr2nU+dJ5yETk=
sudo /home/luke/bin/caddy run
Fedora 32
N/A
admin off
local_certs
mytesthost.com:61000 {
bind 192.168.1.2
root * /home/luke/srv/test/
I have BigIP F5 firewall that opens port 443 for https and manages SSL cert. How Do i configure CaddyServer to work in that configuration. Normally all our web servers work on port 80 without ssl, since they are behind firewall and all traffic within internal network does not have to be encrypted.
My caddyfile is the last version of things that I tried
Just open port 80/443 on your firewall and caddy will automatically get the certs and configure itself as long as you have an A record pointing to mytesthost.com. There isn’t much to do, your config looks fine.
Not sure what these are for though, might want to remove them to do a test first.
admin off
local_certs
Just have;
bind 192.168.1.2
Check your syslog file for errors.
For anybody that wants to create this configuration… I made it work.
Server configuration:
  1. Fedora 32 Server
  2. Caddyserver v2.1 with following Cadyfile:
     admin off
    next-app.xxxxxxxx.com {
     bind 192.168.1.199
     	level DEBUG
     	output stdout
     	format json
  3. BigIP configuration:
  • Two virtual servers, one for port 80 and one for port 443, both have athe same pool with a member 192.168.1.199 for all services (port *)
  • Virtual Server with port 443 has no HTTP, SSL Client and SSL Server profile selected and I enabled Address Translation and Port Translation and setting Source Address Translation to AutoMap
