Configuration Validation Error
I am trying to setup remote admin endpoint with cert auth. I am getting a json validation error, when copying the configuration directly from the documentation and editing it for my values.
When I issue the command
caddy validate --config caddyconfig.json
I get the following output.
root@caddy1:/etc/caddy# caddy validate --config caddyconfig.json
2025/02/07 20:36:04.937 INFO    using config from file  {"file": "caddyconfig.json"}
Error: config is not valid JSON: invalid character '}' looking for beginning of object key string; did you mean to use a config adapter (the --adapter flag)?
via ubuntu apt install command listed on the documentation
Linux caddy1 6.8.0-52-generic #53-Ubuntu SMP PREEMPT_DYNAMIC Sat Jan 11 00:06:25 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
I am using the json not caddyfile
        "admin": {
                "identity": {
                        "identifiers": ["caddy1.vm.local"],
                "remote": {
                        "listen": "1122",
                        "access_control": [{
                                "public_keys": ["blahblah"],
You have extra commas , where they shouldn’t be
Try this:
        "admin": {
                "identity": {
                "remote": {
                        "listen": "1122",
Compare it with yours. Like @Mohammed90 said, you have extra commas in the wrong places.
