I’m using snippets in the Caddyfile in order to reuse as much configuration content as possible and to avoid copying&pasting and producing errors due to gettings those copy&paste clones out of sync.
Now I am wondering whether I can do conditionals within snippets.
Consider a Caddyfile as follows:
(logging) {
format transform "{common_log}" ### how can I make this conditional?
output file /var/log/caddy/{args[0]}.log {
roll_size 10mb
roll_keep 5
(common) {
# Enable headers for all sites here ...
import logging {args[0]}
(common_proxy_https) {
reverse_proxy {args[1]} {
tls_server_name {host}
import common {args[0]}
# Global options
import logging caddy
events {
on cert_obtained exec ...
# Reverse proxies
host1.example.tld {
import common_proxy_https service1 https://service1.local
host2.example.tld {
import common_proxy_https service2 https://service2.local
host3.example.tld {
import common_proxy_https service3 https://service3.local
I would like to keep JSON log format for the main caddy.log (via global options import logging caddy) but for the actual reverse proxies I would like to have traditional Apache access log format in order for fail2ban to work.
Therefore my question: Is it possible to have a conditional on {args[0]} != "caddy" within snippet (logging) so that the format transform "{common_log}" is only active if it is not the main caddy log?
No error messages, I’d like to improve Caddyfile configuration.
$ caddy version
x86_64 Debian GNU/Linux
I diverted custom caddy according to the documentation at Build from source — Caddy Documentation
n/a
See above.
n/a
