Conditionally echoing header parts with header_regexp
1. Output of caddy version:
Docker, official “caddy” image
docker run --rm -p 127.0.0.1:81:80 -v "$(pwd)/static-service:/static-service:ro" -v "$(pwd)/Caddyfile-rewrite:/etc/caddy/Caddyfile:ro" caddy caddy version
Variant A
Building a named matcher:
(frame-embedding-headers) {
	@one-of-ours header_regexp refhost Referer "(https://(.*\.)?(domain1|domain2|domain3)\.com).*"
	header not @one-of-ours X-Frame-Options "DENY"
	header @one-of-ours X-Frame-Options "ALLOW-FROM {re.refhost.1}"
	import frame-embedding-headers
	file_server /* {
		root /static-service
Variant B
Spelling out the matcher in the header directive.
	header not header_regexp refhost Referer "(https://(.*\.)?(domain1|domain2|domain3)\.com).*" X-Frame-Options "DENY"
	header header_regexp refhost Referer "(https://(.*\.)?(domain1|domain2|domain3)\.com).*" X-Frame-Options "ALLOW-FROM {re.refhost.1}"
	file_server /* {
Variant C
Putting the config direct, not as a snippet:
	file_server /* {
I want to set X-Frame-Options to protect ancient browsers from click hijacking.
You can only set one X-Frame-Options header, with one ALLOW-FROM domain expression.
Hence, I want to echo the Referer Header’s Host.
I tried various things that failed on a syntax level, and distilled it to two versions of valid syntax (named matcher and literal matcher), neither of which works.
Variant A
No Referer header:
$ curl -v http://localhost:81
*   Trying 127.0.0.1:81...
* Connected to localhost (127.0.0.1) port 81 (#0)
> GET / HTTP/1.1
> Host: localhost:81
> User-Agent: curl/7.79.1
< HTTP/1.1 200 OK
< Accept-Ranges: bytes
< Content-Length: 108
< Content-Type: text/html; charset=utf-8
< Etag: "rlecry30"
< Last-Modified: Tue, 15 Nov 2022 16:07:10 GMT
< Server: Caddy
< Date: Wed, 16 Nov 2022 14:17:26 GMT
<html>
<body>
</body>
</html>
:x:
Non-matching Referer header:
curl -H "Referer: https://pepi.lacht" -v http://localhost:81
> GET / HTTP/1.1
> Host: localhost:81
< HTTP/1.1 200 OK
< Etag: "rlecry30"
< Server: Caddy
< Date: Wed, 16 Nov 2022 14:24:05 GMT
<html>
<body>
</body>
</html>
Expected: X-Frame-Options: DENY; Actual: No header.
:x:
Matching Referer header:
$ curl -H "Referer: https://domain1.com" -v http://localhost:81
> GET / HTTP/1.1
> Host: localhost:81
< HTTP/1.1 200 OK
< Etag: "rlecry30"
< Server: Caddy
< X-Frame-Options: ALLOW-FROM https://domain1.com
< Date: Wed, 16 Nov 2022 14:25:18 GMT
<html>
<body>
</body>
</html>
Expected: X-Frame-Options: ALLOW-FROM https://domain1.com
Actual: X-Frame-Options: ALLOW-FROM https://domain1.com
:white_check_mark:
Variant B
All three Calls give the same Output:
> GET / HTTP/1.1
> Host: localhost:81
< HTTP/1.1 200 OK
< Etag: "rlecry30"
< Server: Caddy
< X-Frame-Options: ALLOW-FROM {http.regexp.refhost.1}
< Date: Wed, 16 Nov 2022 14:32:41 GMT
<html>
<body>
</body>
</html>
I.e. the positive match seems to be taken no matter whether the Header is even present, but doesn’t fill the {re.…} expression even when it should match?!
:x:, :x: and :x:
Variant C
As expected behaved exactly like Variant A
Variants A and B + a few that were rejected by validate up front.
I checked my RE with the Golang RE checker and they matched exactly as expected (incl. groups).
That’s not valid syntax. You can’t use not inline, and you can’t use a named matcher as an argument to another matcher.
Please review the request matcher syntax documentation, it shows what is valid.
That said, to solve your issue, I recommend you read this article:
Thanks, just these two notes made it easy to fix, at the price of repeating the regex. I guess I can make the regex a snippet argument, I’ll have to check that. Baseline is that this – based on your hints – works, for people who might find this later:
  header +Content-Security-Policy "frame-ancestors https://*.domain1.com https://*.domain2.com https://*.domain3.com;"
  @one-of-ours header_regexp refhost Referer "(https://(.*\.)?domain[123]\.com).*"
  @not-ours {
    not {
      header_regexp Referer "(https://(.*\.)?domain[123]\.com).*"
  header @not-ours X-Frame-Options "DENY"
foo.domain1.com {
Quick feedback/impression:
I did review the documentation just now. Unless I was looking in the wrong place (see links below), I still feel these issues are not clear from it:
First item says:
not <any other matcher>
This looks
a) inline, and
b) says any other matcher:
Says “All matchers that are not path or wildcard matchers must be named matchers. This is a matcher that is defined outside of any particular directive, and can be reused.”
This makes it sound like named matchers are matchers and can be used such. The rest of the named matcher section does not note that named matchers are not composable (e.g. with not).
Beyond the specific docs on named matchers & not, to my understanding, not being clear on the issue, I think it would be super useful if this was no issue.
The inline syntax not being general, and some types of matchers being composable and some not,
IMO hurts orthogonality/composability of the otherwise great and extremely compact syntax.
You can simplify this:
  @not-ours not header_regexp Referer "(https://(.*\.)?domain[123]\.com).*"
To clarify, what isn’t inline is matchers in general. You can only “inline” a path matcher token, or a named matcher token, to a directive.
But you can use single-line syntax for not when defining a named matcher.
