Comments on my caddyfile
No specific issue would just like an extra set of eyes on my Caddyfile as I followed a guide and don’t want to do anything stupid. Is there anything wrong with how it’s composed or anything I should consider adding or amending?
NA
Followed the official guide for initial installation.
Windows 11 Pro
./Caddy run
NA
jelly.lolwtf.uk {
    reverse_proxy 192.168.1.74:8099
lidarr.lolwtf.uk {
    reverse_proxy localhost:8686
emby.lolwtf.uk {
    reverse_proxy localhost:8096
sonarr.lolwtf.uk {
    reverse_proxy localhost:8989
radarr.lolwtf.uk {
    reverse_proxy localhost:7878
sab.lolwtf.uk {
    reverse_proxy localhost:8085
NA
Nope, that’s all you need! If the apps work fine, nothing to do.
Yeah it’s working perfectly. I have just been shocked how easy it was to set up. Coming from a Linux background and switching to Win for me has been a struggle.
I tried IIS and failed, I had nginx up and running but forgot how clunky it was.
Is there a recommended method to have my caddy autostart from boot on Windows?
Yep, you have a couple options: Keep Caddy Running — Caddy Documentation
