1. Output of caddy version
v2.6.1
I run caddy on an an Oracle Ampere instane under systemctl
Ubunutu 22.04 ARM64
systemctl start caddy
Not using docker
# Main WordPress Site
www.andy-milne.com {
root * /var/www/andymilne
php_fastcgi unix//run/php/php8.1-fpm.sock
encode zstd gzip
# disable FLoC tracking
Permissions-Policy interest-cohort=()
# enable HSTS
# clickjacking protection
X-Frame-Options DENY
@disallowed {
path /xmlrpc.php
path *.sql
path /wp-content/uploads/*.php
rewrite @disallowed '/index.php'
@denied_folders path /wp-admin/*
@denied not remote_ip my_static_IP
abort @denied
I am trying to allow access to Log In ‹ Andy Milne — WordPress only from my static IP. I have tried various combinations of denied_folders and not remote_ip but I havn’t found a way to combine both. I can block all access to /wp-admin/ easily and alternately I can deny access to any IP that is not my static IP but not how to combine both. Putting both parameters on the same line produced a systemctl start error. I am guessing it is the formating and layout so any help would be great thanks assuming you can combine parameters.
No error message, just a way to combine both commands as 1 and 2.
Various combinations but I am new to writing Caddy configs so I could flail around for days. I did read the documenation and did many earches but can’t find a way to combine these two parameters.
None.
