Colon in default env var
The documentation on default environment vars in caddy is rather sparse.
so I’m having trouble setting a default var for a tls url.
In my global section I have:
{	acme_ca ${ACME_URL:"https://acme-staging-v02.api.letsencrypt.org/directory"}
The intent is that if no ACME_URL environment variable exists then the acme_ca should default to the staging url for lets encrypt.
I’ve tried both with and without quotes around the url.
I’ve also tried escaping the colon after the https http\://acme...'
{"level":"error","ts":1743892471.53229,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.onepub.dev","issuer":"${ACME_URL:\"https://acme-staging-v02.api.letsencrypt.org/directory\"}","error":"parse \"${ACME_URL:\\\"https://acme-staging-v02.api.letsencrypt.org/directory\\\"}\": first path segment in URL cannot contain colon"}
{"level":"error","ts":1743892471.532569,"logger":"tls.obtain","msg":"will retry","error":"[*.onepub.dev] Obtain: parse \"${ACME_URL:\\\"https://acme-staging-v02.api.letsencrypt.org/directory\\\"}\": first path segment in URL cannot contain colon","attempt":1,"retrying_in":60,"elapsed":0.001460799,"max_duration":2592000}
I building caddy in a docker file.
FROM caddy:2.9.1-builder AS builder
https://hub.docker.com/repository/docker/onepub/onepub-caddy/tags/4.63.118/sha256-c13efa82a71577aa5085b99b4fdcd906413475978ab342a47438f9584559254e
docker
docker on linux.
# we build our own caddy file as we need the cloudflare module.
# https://caddyserver.com/docs/modules/dns.providers.cloudflare
RUN xcaddy build \
    --with github.com/WeidiDeng/caddy-cloudflare-ip
FROM caddy:2.9.1
COPY config/caddy /etc/caddy
# CMD ["tail", "-f", "/dev/null"]
CMD ["caddy", "run", "--config", "/etc/caddy/Caddyfile", "--adapter", "caddyfile"]
	# Email for Let's Encrypt notifications
	email {$EMAIL}
	# ACME CA URL allows us to flip between production and staging.
	# we default to staging.
        output stdout
	# trigger the cloudflare ip module that periodically fetchs
    # the list of valid cloud flare proxy IP addresses.
	servers {
		trusted_proxies cloudflare {
			interval 12h
			timeout 15s
# Main Domain Configuration
*.onepub.dev, onepub.dev {
		# API Token required for Wild card certs
	# Remove duplicate slashes from the URI
	# (e.g., /path//to///resource) but avoids the query string
	@multiple_slashes path_regexp multipleSlashes ^(.*)//+(.*)$
	redir @multiple_slashes {scheme}://{host}{re.multipleSlashes.1}/{re.multipleSlashes.2}{query} permanent
	# Block common AI crawler User-Agents
	@block_ai header_regexp User-Agent "(?i)(GPTBot|ChatGPT|Google-Extended|Claude-Web|Anthropic|Amazonbot|FacebookBot|cohere-ai|Bytespider|YouBot)"
	respond @block_ai 403
	# Block all PHP file requests, returning no response (similar to nginx 444)
	@block_php path *.php
	abort @block_php
	# Redirect all .mp4 requests permanently (HTTP 301) to video subdomain
	@mp4_redirect path *.mp4
	redir @mp4_redirect https://video.{host}{uri} permanent
	handle /mailhog/* {
		basic_auth {
			# password is in lastpass under 'mailhog on production'
			# hash is generated by running caddy hash-password.
			bsutton XXXX
		reverse_proxy 127.0.0.1:8025
	handle /api/* {
		reverse_proxy 127.0.0.1:8080 {
			header_up Host {host}
				read_timeout 300s
			# Required for WebSocket support
			header_up Connection {header.Connection}
			header_up Upgrade {header.Upgrade}
	# Global error handling, applied only for API endpoints
	handle_errors {
		@api path /api/*
		handle @api {
			root * /etc/caddy/json
			rewrite 502 /500.json
			rewrite 404 /404.json
			read_timeout 300s
# Combined Video Domains Configuration
# we serve video on the video subdomain, because it would violate
# cloudflare TOS to proxy video through cloudflare
video.onepub.dev, video.beta.onepub.dev {
		Strict-Transport-Security "max-age=31536000; includeSubDomains"
		X-Frame-Options "SAMEORIGIN"
	handle /*.mp4 {
			header_up X-Forwarded-Proto https
				read_timeout 300s
			# Web sc
	# Domain-based redirection (fallback)
	@prod host video.onepub.dev
	redir @prod https://onepub.dev{uri} permanent
	redir https://beta.onepub.dev{uri} permanent
That seems to be incorrect. You probably want:
{	acme_ca {$ACME_URL:"https://acme-staging-v02.api.letsencrypt.org/directory"}
Notice the dollar sign position. See this for more details:
Yes that fixed it.
docker uses ${xx} and caddy {$xx}…
