I’m trying to get acces to my website from outside my LAN. I’m running ubuntu in a VM on Unraid, in which I use caddy and gunicorn to run my (flask) website. When I use my LAN IP (192.168.0.104) I can visit my website and everything works fine. To acces some dockers on unraid I use cloudflare tunnels, and I really like working with that so I tried to use the same for this website. On the dockers I used to just create a subdomain that points to the IP adress of the docker and turn off TLS verify and it works flawlessly. Doing the same for my website does not work. I used the IP adress i get when running ifconfig, for the cloudflare tunnel.
Mostly my problem is that I don’t fully understand how cloudflare tunnels work, or how to set up caddy to work on a specific domain instead of the IP that I get from ifconfig.
I don’t know how to get log output, caddy runs fine if I use my LAN IP.
v2.7.5
sudo apt update
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
curl -1sLf 'https://dl.cloudsmith.io/public/caddy... | sudo gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg
curl -1sLf 'https://dl.cloudsmith.io/public/caddy... | sudo tee /etc/apt/sources.list.d/caddy-stable.list
sudo apt update
sudo apt install caddy
sudo apt install python3-pip python3-dev build-essential libssl-dev libffi-dev python3-setuptools
sudo apt install python3-venv
Ubuntu 22.04.3 LTS
as a VM in unraid
sudo caddy start
gunicorn run:app
I don’t know what this is.
my_domain.be {
reverse_proxy localhost:8000
