Hello,
First of all, I just want to say that I like Caddy Server a lot. My intent is to use for a reverse proxy. I’m coming from NGINX Proxy Manager, which is very buggy, to Caddy and I like how it works, how fast it is, reliable and how it’s configured. Also, I tried every wiki and tutorial possible, either here, reddit or other sources, but they don’t seem to apply to my case or configuration. See below for further explanation.
When I use the cloudflare tunnel to connect to my Caddy reverse proxy, I’m getting “host error”, which does not happen when I point the cloudflare tunnel to the NGINX Proxy Manager instance that I have running.
Note that locally, all works fine and well with Caddy. The problem is only when it is going through the cloudflare tunnel. An important thing is that I use a wildcard certificate. Also, some services I run with a mTLS certificate. Other services, I don’t. Further down, my Caddyfile will show how I set this up.
My cloudflare tunnel config.yml:
tunnel: <tunnel_UUID>
credentials-file: /etc/cloudflared/<tunnel_UUID>.json
ingress:
- hostname: '*.mydomain.net'
service: https://<caddy_lxc_ip>:443
originRequest:
noTLSverify: true
originServerName: '*.mydomain.net'
httpHostHeader: '*.mydomain.net'
- service: http_status:404
Note that I tried all sorts of combinations with the options on the originRequest in the configuration, but to no avail.
{"level":"info","ts":1738949007.8934052,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1738949007.8949847,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0005c6480"}
{"level":"info","ts":1738949007.8952591,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"warn","ts":1738949007.8952835,"logger":"http","msg":"enabling strict SNI-Host enforcement because TLS client auth is configured","server_id":"srv0"}
{"level":"info","ts":1738949007.8966854,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1738949007.8973846,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"warn","ts":1738949007.897432,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"warn","ts":1738949007.897441,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"info","ts":1738949007.8974454,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1738949007.8974502,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["*.mydomain.net"]}
{"level":"info","ts":1738949007.8979354,"msg":"autosaved config (load with --resume flag)","file":"/root/.config/caddy/autosave.json"}
{"level":"info","ts":1738949007.897953,"msg":"serving initial configuration"}
{"level":"info","ts":1738949007.9025705,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/root/.local/share/caddy","instance":"7ee4f97f-d64d-434a-8010-2d645bd326b9","try_again":1739035407.9025645,"try_again_in":86399.999998044}
{"level":"info","ts":1738949007.902646,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1738956807.9011948,"logger":"tls.cache.maintenance","msg":"reloaded ARI with newer one in storage","identifiers":["*.mydomain.net"],"cert_hash":"6cbd7b39debde2e888762f509c65fe9b307c6bff8651e250bf94ae455855b216","ari_unique_id":"kydGmAOpUWiOmNbEQkjbI79YlNI.AxedazOBd_uPcaTvcY0wAyn3","cert_expiry":1746164729,"next_refresh":1738978194.3478506,"renewal_time":1743637188}
{"level":"info","ts":1738965571.6347935,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/stop","remote_ip":"127.0.0.1","remote_port":"48060","headers":{"Accept-Encoding":["gzip"],"Content-Length":["0"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
{"level":"warn","ts":1738965571.634828,"logger":"admin.api","msg":"exiting; byeee!! 👋"}
{"level":"info","ts":1738965571.6348436,"logger":"http","msg":"servers shutting down with eternal grace period"}
{"level":"info","ts":1738965571.6362305,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
{"level":"info","ts":1738965571.63625,"logger":"admin.api","msg":"shutdown complete","exit_code":0}
{"level":"info","ts":1738965578.3277547,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1738965578.3284423,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0008ae880"}
{"level":"info","ts":1738965578.3288624,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"warn","ts":1738965578.3288896,"logger":"http","msg":"enabling strict SNI-Host enforcement because TLS client auth is configured","server_id":"srv0"}
{"level":"info","ts":1738965578.3302643,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1738965578.3304112,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"warn","ts":1738965578.3304396,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"warn","ts":1738965578.3304534,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"info","ts":1738965578.330458,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1738965578.3304622,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["*.mydomain.net"]}
{"level":"info","ts":1738965578.3309326,"msg":"autosaved config (load with --resume flag)","file":"/root/.config/caddy/autosave.json"}
{"level":"info","ts":1738965578.3309417,"msg":"serving initial configuration"}
{"level":"info","ts":1738965578.336066,"logger":"tls","msg":"cleaning storage unit","storage":"FileStorage:/root/.local/share/caddy"}
{"level":"info","ts":1738965578.3395813,"logger":"tls","msg":"finished cleaning storage units"}
I have a Proxmox server where I have one LXC for the Cloudflare Tunnel (cloudflared) and another LXC with Caddy. Both LXC’s were generated based on the nice people at helper-scripts.com
The Caddy LXC is Debian 12.
sudo caddy fmt --overwrite
sudo caddy adapt
sudo caddy run
N/A
auto_https prefer_wildcard
output file /var/log/access.log
(localonly) {
@denied not remote_ip private_ranges
abort @denied
(mtls) {
client_auth {
mode require_and_verify
trust_pool file <file_directory>/ca.pem
*.mydomain.net {
dns cloudflare {env.CLOUDFLARE_API_KEY}
service1.mydomain.net {
reverse_proxy <service1_ip>:<service1_port>
service2.mydomain.net {
import localonly
import mtls
reserve_proxy <service2_ip>:<service2_port>
When I run the service1 from the cloudflare tunnel, I get the host error as mentioned.
