2.4.6
i use caddy as a reverse proxy, the DNS is connected to Cloudflare nameservers
windows 10
.\caddy run
domian {
reverse_proxy localhost:8096
tls E:\Server\Certs\certificate.pem E:\Server\Certs\key.pem
Im trying to import cloud flares SSL certificates to caddy however i believe im using the wrong format. im using the format ive found for linux guides however i dont believe this works on windows 10 and im wondering if anyone knows the correct format or what im doing wrong.
2022/04/17 08:42:24.211 ←[34mINFO←[0m using adjacent Caddyfile
2022/04/17 08:42:24.212 ←[33mWARN←[0m Caddyfile input is not formatted; run the ‘caddy fmt’ command to fix inconsistencies {“adapter”: “caddyfile”, “file”: “Caddyfile”, “line”: 4}
2022/04/17 08:42:24.221 ←[34mINFO←[0m admin admin endpoint started {“address”: “tcp/localhost:2019”, “enforce_origin”: false, “origins”: ["//localhost:2019", “//[::1]:2019”, “//127.0.0.1:2019”]}
2022/04/17 08:42:24.221 ←[34mINFO←[0m tls.cache.maintenance started background certificate maintenance {“cache”: “0xc00070b810”}
2022/04/17 08:42:24.225 ←[33mWARN←[0m tls stapling OCSP {“error”: “no OCSP stapling for [cloudflare origin certificate *.domain domain]: no URL to issuing certificate”}
2022/04/17 08:42:24.225 ←[34mINFO←[0m http skipping automatic certificate management because one or more matching certificates are already loaded {“domain”: " domain", “server_name”: “srv0”}
2022/04/17 08:42:24.225 ←[34mINFO←[0m http enabling automatic HTTP->HTTPS redirects {“server_name”: “srv0”}
2022/04/17 08:42:24.225 ←[34mINFO←[0m tls cleaning storage unit {“description”: “FileStorage:C:\Users\account\AppData\Roaming\Caddy”}
2022/04/17 08:42:24.228 ←[34mINFO←[0m autosaved config (load with --resume flag) {“file”: “C:\Users\account\AppData\Roaming\Caddy\autosave.json”}
2022/04/17 08:42:24.228 ←[34mINFO←[0m serving initial configuration
Successfully started Caddy (pid=18160) - Caddy is running in the background
2022/04/17 08:42:24.232 ←[34mINFO←[0m tls finished cleaning storage units
searched doc and google but all are for linux.
Hope this is enough information and thank you for any future responses
