Cloudflare should be integrated by default instead of using custom build.
Because I want to use the Caddy docker version but the official build doesn’t support Cloudflare.
We’re careful about bundling more than absolutely necessary. Only a small percentage of users actually use CloudFlare, so it’s just extra bloat to include it. Plus it isn’t maintained by the core Caddy team.
You can easily build a Docker image with the CloudFlare plugin, see the docs on Docker Hub specifically the part “Adding custom Caddy modules”.
