Cloudflare: Caddyfile:8: unrecognized directive: dns
I currently run caddy in my homedir with:
./caddy run --config Caddyfile
macOS Catalina, latest version
xcaddy build --with github.com/caddy-dns/cloudflare
    email <redactd>
    experimental_http3
code.example.no {
    reverse_proxy 127.0.0.1:8080
I am trying to start caddy with my configuration, but I get a configuration error which I cannot seem to figure out. The configuration is from the last example on this page: tls (Caddyfile directive) — Caddy Documentation
2020/05/07 20:56:39.250	INFO	using provided configuration	{"config_file": "Caddyfile", "config_adapter": ""}
run: adapting config using caddyfile: Caddyfile:8: unrecognized directive: dns
See 3.
Hi @kradalby, welcome to the Caddy community!
Please note some of the pointers from the Caddyfile documentation:
  • An optional global options block can be the very first thing in the file.
  • Otherwise, the first line of the Caddyfile is always the address(es) of the site to serve.
  • All directives and matchers must go in a site block. There is no global scope or inheritence across site blocks.
—Caddyfile Concepts — Caddy Documentation
You have placed the tls directive outside of a site block.
Therefore, Caddy is interpreting tls as the site label (the name of the site you want to serve), and is trying to interpret dns as a directive for configuring that site. As the error notes, dns is not a directive, so this causes a problem.
The examples in the tls documentation are intended to go inside a site block.
ah thank you @Whitestrake, that worked.
I was sure I had tried that, but I must have seen myself blind in a brute force attempt.
