I’ve been able to successfully get Caddy setup and running as a “middle-man” between Cloudflare and a Ubuntu server being managed by Runcloud.io.
Using website.com as our example:
Caddy server running at IP 1.2.3.4
Ubuntu server running at IP 5.6.7.8
Domain settings at Cloudflare:
- DNS Entries proxied and pointed at our Caddy IP of 1.2.3.4
- Under SSL/TLS > Overview, set option to Full
Caddyfile entry on Caddy server:
website.com, www.website.com {
tls internal
reverse_proxy 5.6.7.8:80
Application entry for website.com on Ubuntu (managed by Runcloud.io):
- Under SSL/TLS, generate a new Let’s Encrypt cert
- Use http-01 authorization
- Use No Redirection
The above example will load your domain successfully using a Cloudflare IP.
