Cloudflare + Caddy + TLS not working
Caddy + Cloudflare + TLS not working.
I am trying to setup TLS using caddy on a domain name. The domain name is under cloudflares DNS:
On cloudflares side:
  • DNS only (grey cloud)
  • TLS to ‘Full (strict)’
On my server side I supply the following Caddyfile:
    email info@DOMAIN.io
DOMAIN.io:443{
    reverse_proxy 127.0.0.1:8888
        output file /var/log/caddy/DOMAIN.io.log
    handle_errors {
        respond "Something went wrong" 500
curl results:
user@machine:~$ curl -IL https://DOMAIN.io/swagger-ui/
*Stays blank*
When I tried the following configuration everything worked fine but no TLS.
    auto_https off
DOMAIN.io:80{
    handle_errors {
curl result:
user@machine:~$ curl -IL http://DOMAIN.io/swagger-ui/
HTTP/1.1 200 OK
Content-Length: 734
Content-Type: text/html
Date: Sat, 14 Sep 2024 10:55:29 GMT
Server: Caddy
Connection: close
No error messages come in. Only firefox shows: ERR_TIMED_OUT
root@server:~ # caddy version
Caddy was installed via the ubuntu install instructions Install — Caddy Documentation
root@ubuntu-4gb-nbg1-2:~# lsb_release -d
No LSB modules are available.
Description:    Ubuntu 24.04 LTS
root@ubuntu-4gb-nbg1-2:~# uname -a
Linux ubuntu-4gb-nbg1-2 6.8.0-44-generic #44-Ubuntu SMP PREEMPT_DYNAMIC Tue Aug 13 13:35:26 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
systemctl start caddy
DOMAIN.io:443 {
            output file /var/log/caddy/a.io.log
    handle_errors {
I would like to thank anyone in advance for their help and time
WAF blocked port 443 :melting_face:
