I’m trialling caddy as a reverse proxy and have attempted to set up client cert auth as per the docs using the trust_pool file directive. However, I seem to get some strange results that I’m struggling to diagnose. The Home Assistant app which has the client cert works fine. Chrome does not; it throws an error stating ERR_BAD_SSL_CLIENT_AUTH_CERT and never asks me to present a client cert. I’m new to caddy so it’s probably a misunderstanding on my part but I’ve been through the docs and can’t find what I’m doing wrong.
Chrome errors:
This site can't provide a secure connection
<FQDN> didn't accept your login certificate, or one may not have been provided
Try contacting the system admin
Caddy access logs look fine, I can’t see anything bouncing there and the caddyfile obviously loads without complaint.
Worryingly, because I don’t understand this issue, the Home Assistant app seems to work fine both across ipv4 and ipv6. Chrome exhibits the same behaviour across both stacks.
v2.8.4 from apt
Installed from apt as per the docs: Install — Caddy Documentation
AWS Lightsail instance running Ubuntu 22.04 exposing both ipv4 and ipv6 endpoints
$ caddy start
$ caddy reload --config /etc/caddy/Caddyfile
2024/07/21 20:25:39.921 INFO using config from file {"file": "/etc/caddy/Caddyfile"}
2024/07/21 20:25:39.922 INFO adapted config to JSON {"adapter": "caddyfile"}
n/a
(mutual_tls) {
protocols tls1.2 tls1.2
client_auth {
mode require_and_verify
#trusted_ca_cert_file /etc/caddy/ca.crt
#trusted_leaf_cert_file /etc/caddy/hass.crt
trust_pool file {
pem_file /etc/caddy/ca.crt
# HomeAssistant
<fqdn of caddy> {
roll_size 10mb
roll_keep 5
roll_keep_for 168h
import mutual_tls
reverse_proxy https://192.168.100.1:443 {
tls_server_name <fqdn of wireguard remote peer which port forwards on to the nginx origin server>
My ca.crt file is a PEM encoded openssl generated CA with no intermediate and is valid.
n/a
