I am setting up the circuit breaker module and have a hard time configuring it via Caddyfile.
Unfortunately, adding a circuit_breaker block results in an error. The documentation over this module is absent, so I’m not sure how to configure it using Caddyfile and whether it’s possible (maybe it’s only configurable via JSON?). I would be glad if you could help me fixing the Caddyfile, thanks.
Also I’m not sure what unit does threshold config option use, did I assume percents of requests correctly?
Error: adapting config using caddyfile: /etc/caddy/Caddyfile:18: unrecognized directive: circuit_breaker
v2.7.6
Caddy is deployed via Helm as a sidecar container to the pod, alongside the application server, and is intended to run as a reverse proxy that implements circuit breaker functionality.
AWS EKS v1.26, Linux x86_64, containerd v1.6.19
admin :2019 # binds admin API on all interfaces, not only localhost. Required to scrape metrics
auto_https off
log
servers {
metrics
trusted_proxies static <redacted>
order rate_limit before basicauth
:8080 {
rate_limit {remote.ip} 2r/s # remote.ip corresponds to the first IP in the X-Forwarded-For header
header -<redacted>
header -<redacted>
reverse_proxy :5001 {
circuit_breaker {
threshold 50
header_up -<redacted>
