v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=
Gentoo Linux 5.13.19
# http_port 60001
auto_https off
output file /var/log/caddy/main/caddy_main.log {
roll_size 100MiB
roll_keep_for 100d
format json
servers [2001:470:28:704::100]:443 {
protocol {
experimental_http3
servers [2001:470:28:704::100]:80 {
protocol {
## Hosts section
import vhosts/*.caddy
file: vhosts/wiki.tnonline.net.caddy
wiki.tnonline.net:443 {
tls /etc/letsencrypt/live/wiki.tnonline.net/fullchain.pem /etc/letsencrypt/live/wiki.tnonline.net/privkey.pem {
bind 2001:470:28:704::100
output file /var/log/caddy/wiki.tnonline.net_443.log {
roll_size 100MiB
roll_keep_for 100d
format json
encode zstd gzip
@title {
not file {
try_files {path} {path}/
split_path .php
path_regexp title ^/(.*)$
rewrite @title /mediawiki/index.php?title={re.title.1}&{query}
redir / /w/Main_Page
root * /var/www/domains/wiki.tnonline.net/htdocs
php_fastcgi unix//var/run/php-fpm/fpm-wiki.socket
wiki.tnonline.net:80 {
output file /var/log/caddy/wiki.tnonline.net_80.log {
roll_size 100MiB
roll_keep_for 100d
format json
@https not path /.well-known/*
redir @https https://wiki.tnonline.net/ permanent
I’d like to enable cipher suites so that Windows 7/8 clients with IE 11 can connect, like then can with my Apache installation.
Caddy: SSL Server Test: wiki.tnonline.net (Powered by Qualys SSL Labs)
Apache: SSL Server Test: wiki.tnonline.net (Powered by Qualys SSL Labs)
My apache config has the following TLS Priorities:
GnuTLSPriorities PFS:-VERS-ALL:+VERS-TLS1.3:+VERS-TLS1.2:+VERS-DTLS1.2:-GROUP-ALL:+GROUP-X25519:+GROUP-X448:+GROUP-SECP521R1:+GROUP-SECP384R1:+GROUP-SECP256R1:-SHA1:-MD5:-AES-256-CBC:-AES-256-CCM:-AES-128-CBC:-AES-128-CCM:-CIPHER-ALL:+CHACHA20-POLY1305:+AES-256-GCM:+AES-128-GCM:+SHA384:+SHA256:+AES-256-GCM:+ECDHE-ECDSA:+ECDHE-RSA:%SERVER_PRECEDENCE
testssl.sh outputs:
Apache:
Testing server's cipher preferences
Has server cipher order? yes (OK) -- TLS 1.3 and below
Negotiated protocol TLSv1.3
Negotiated cipher TLS_CHACHA20_POLY1305_SHA256, 253 bit ECDH (X25519)
Cipher per protocol
Hexcode Cipher Suite Name (OpenSSL) KeyExch. Encryption Bits Cipher Suite Name (IANA/RFC)
SSLv2
SSLv3
TLSv1
TLSv1.1
TLSv1.2 (server order)
xcca8 ECDHE-RSA-CHACHA20-POLY1305 ECDH 253 ChaCha20 256 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
xc030 ECDHE-RSA-AES256-GCM-SHA384 ECDH 253 AESGCM 256 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
xc02f ECDHE-RSA-AES128-GCM-SHA256 ECDH 253 AESGCM 128 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
xccaa DHE-RSA-CHACHA20-POLY1305 DH 4096 ChaCha20 256 TLS_DHE_RSA_WITH_CHACHA20_POLY1305_SHA256
x9f DHE-RSA-AES256-GCM-SHA384 DH 4096 AESGCM 256 TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
x9e DHE-RSA-AES128-GCM-SHA256 DH 4096 AESGCM 128 TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
TLSv1.3 (server order)
x1303 TLS_CHACHA20_POLY1305_SHA256 ECDH 253 ChaCha20 256 TLS_CHACHA20_POLY1305_SHA256
x1302 TLS_AES_256_GCM_SHA384 ECDH 253 AESGCM 256 TLS_AES_256_GCM_SHA384
x1301 TLS_AES_128_GCM_SHA256 ECDH 253 AESGCM 128 TLS_AES_128_GCM_SHA256
...snip
Browser Protocol Cipher Suite Name (OpenSSL) Forward Secrecy
Android 4.4.2 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 521 bit ECDH (P-521)
Android 5.0.0 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 521 bit ECDH (P-521)
Android 6.0 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 384 bit ECDH (P-384)
Android 7.0 (native) TLSv1.2 ECDHE-RSA-CHACHA20-POLY1305 256 bit ECDH (P-256)
Android 8.1 (native) TLSv1.2 ECDHE-RSA-CHACHA20-POLY1305 253 bit ECDH (X25519)
Android 9.0 (native) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Android 10.0 (native) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Chrome 74 (Win 10) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Chrome 79 (Win 10) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Firefox 66 (Win 8.1/10) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Firefox 71 (Win 10) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
IE 6 XP No connection
IE 8 Win 7 No connection
IE 8 XP No connection
IE 11 Win 7 TLSv1.2 DHE-RSA-AES256-GCM-SHA384 4096 bit DH
IE 11 Win 8.1 TLSv1.2 DHE-RSA-AES256-GCM-SHA384 4096 bit DH
IE 11 Win Phone 8.1 No connection
IE 11 Win 10 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 384 bit ECDH (P-384)
Edge 15 Win 10 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 253 bit ECDH (X25519)
Edge 17 (Win 10) TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 253 bit ECDH (X25519)
Opera 66 (Win 10) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Safari 9 iOS 9 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 521 bit ECDH (P-521)
Safari 9 OS X 10.11 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 521 bit ECDH (P-521)
Safari 10 OS X 10.12 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 521 bit ECDH (P-521)
Safari 12.1 (iOS 12.2) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Safari 13.0 (macOS 10.14.6) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Apple ATS 9 iOS 9 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 521 bit ECDH (P-521)
Java 6u45 No connection
Java 7u25 No connection
Java 8u161 TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 521 bit ECDH (P-521)
Java 11.0.2 (OpenJDK) TLSv1.3 TLS_AES_256_GCM_SHA384 521 bit ECDH (P-521)
Java 12.0.1 (OpenJDK) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 521 bit ECDH (P-521)
OpenSSL 1.0.2e TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 521 bit ECDH (P-521)
OpenSSL 1.1.0l (Debian) TLSv1.2 ECDHE-RSA-CHACHA20-POLY1305 253 bit ECDH (X25519)
OpenSSL 1.1.1d (Debian) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Thunderbird (68.3) TLSv1.3 TLS_CHACHA20_POLY1305_SHA256 253 bit ECDH (X25519)
Caddy:
Has server cipher order? yes (OK) -- only for < TLS 1.3
Negotiated cipher TLS_AES_128_GCM_SHA256, 253 bit ECDH (X25519)
Cipher per protocol
SSLv2
SSLv3
TLSv1
TLSv1.1
xc02f ECDHE-RSA-AES128-GCM-SHA256 ECDH 256 AESGCM 128 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
xc030 ECDHE-RSA-AES256-GCM-SHA384 ECDH 256 AESGCM 256 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
xcca8 ECDHE-RSA-CHACHA20-POLY1305 ECDH 256 ChaCha20 256 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
TLSv1.3 (no server order, thus listed by strength)
...snip
Running client simulations (HTTP) via sockets
Android 4.4.2 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Android 5.0.0 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Android 6.0 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Android 7.0 (native) TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Android 8.1 (native) TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 253 bit ECDH (X25519)
Android 9.0 (native) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Android 10.0 (native) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Chrome 74 (Win 10) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Chrome 79 (Win 10) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Firefox 66 (Win 8.1/10) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Firefox 71 (Win 10) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
IE 11 Win 7 No connection
IE 11 Win 8.1 No connection
IE 11 Win 10 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Edge 15 Win 10 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 253 bit ECDH (X25519)
Edge 17 (Win 10) TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 253 bit ECDH (X25519)
Opera 66 (Win 10) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Safari 9 iOS 9 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Safari 9 OS X 10.11 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Safari 10 OS X 10.12 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Apple ATS 9 iOS 9 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Java 8u161 TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
Java 11.0.2 (OpenJDK) TLSv1.3 TLS_AES_128_GCM_SHA256 256 bit ECDH (P-256)
Java 12.0.1 (OpenJDK) TLSv1.3 TLS_AES_128_GCM_SHA256 256 bit ECDH (P-256)
OpenSSL 1.0.2e TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 256 bit ECDH (P-256)
OpenSSL 1.1.0l (Debian) TLSv1.2 ECDHE-RSA-AES128-GCM-SHA256 253 bit ECDH (X25519)
OpenSSL 1.1.1d (Debian) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
Thunderbird (68.3) TLSv1.3 TLS_AES_128_GCM_SHA256 253 bit ECDH (X25519)
I did start looking at how to change cipher suites, but it seems that the TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 chipher suite is not supported by Caddy. tls (Caddyfile directive) — Caddy Documentation
