Change ports for usage inside a Container
(devel)
Should be v2, I am using the Container from Docker Hub “caddy/caddy:alpine”
I am starting Caddy with podman on a ArchLinux machine.
OS, relevant versions, systemd? docker? etc.
ArchLinux, Podman not Docker.
podman run --name web_server -d -p 80:8080 -v ./caddy/Caddyfile:/etc/caddy/Caddyfile -v /var/server/web:/var/server/web caddy/caddy:alpine
d. My complete Caddyfile:
# domain name.
# Before it was :8080, that works. But i want to use the automatic HTTPS
www.mydomain.com
root * /var/server/web
# reverse_proxy localhost:8888
# php_fastcgi localhost:9000
# https://github.com/caddyserver/caddy/wiki/v2:-Documentation
I would like to set my domain in the Caddyfile, but I dont want Caddy to bind port 80 or 443 inside the Container. I would like to forward port 80 to 8080 and port 443 to 8081.
So the external ports are 80 and 443, but I don’t want Caddy to bind them. Why not? Because of Security restrictions to the containers I am using.
So Caddy should be able to bind use my Domain for HTTPS with Let’s Encrypt because would be available at port 80 and 443, but should not bind that ports! I would love to set the HTTP and HTTPS ports which are used on my own AND use the automatic HTTPS stuff. :slight_smile:
Just the errors that my container is not allowed to bind lower ports like 80 or 443.
I read the documentation and the forum and could not find a solution for my environment.
None
Hi Simon! Welcome around.
This seems to be a shortcoming of rootless containers in general, and rootless Podman in particular. The page I’ve linked lists solutions.
Hey Mohammed,
thank you for the answer.
I know about the restrictions of podman and I think they are good and useful. That’s the reason I don’t want to change the behavior of podman. I would prefer to configure Caddy to bind ports which I want to use and still start the automatic HTTPS procedure because for the outside world the ports 80 and 443 are available.
I would like to say: Caddy use 8081 for HTTPS and 8080 for HTTP, I will take care that the correct requests are forwarded to you.
Is that possible with a Caddyfile, or maybe with a Json configuration?
With JSON, use http_port and https_port parameters: JSON Config Structure - Caddy Documentation
With Caddyfile, use http_port and https_port options: Global options (Caddyfile) — Caddy Documentation
Thank you Matt!
I somehow missed that global options block! Works like a charme now! Even http2 is there! Thank you! :grinning:
Regards
Simon
