Certificates load by load_pem not working
v2.1.1
caddy cli
Mac
caddy run -config caddy.json
For a specific domain I would like to disable caddy’s automatic certificate retrieval and use my custom certificates.
Therefore I would like register the certificates using the caddy api (json/apps/tls/certificates/load_pem/ — Caddy Documentation 3).
Unfortunately caddy does not recognize the certificates:
"load_pem": [{
"certificate": "-----BEGIN CERTIFICATE----MIIGfzCCBWegAwIBAgISA8A1M8hcnrtS0B9BnyoZpvlHMA0GCSqGSIb3DQEBCwUAMEoxCzAJBgNVBAYTAlVTMRYwFAYDVQQKEw1MZXQncyBFbmNyeXB0MSMwIQYDVQQDExpMZXQncyBFbmNyeXB0IEF1dG[...]-----END CERTIFICATE-----",
"key":"-----BEGIN RSA PRIVATE KEY-----
MIIJNBFTBAAKCAgEA/y7t3GTcrWHJ+lsWGEvhUtAo7/S9l7DHw/A6DW7F88+wO[...]-----END RSA PRIVATE KEY-----"
“error”:“loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision tls: loading certificates: PEM pair 0: tls: failed to find any PEM data in certificate input”}
I already tried to base64 encode both the certificate and the key, but this does not work either (same error message).
run: loading initial config: loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision tls: loading certificates: PEM pair 0: tls: failed to find any PEM data in certificate input
I haven’t played around with that feature, but I think you might need to omit the ASCII armor (the ----- stuff) and only have the base64 contents of the PEM. Have you tried that?
Also, v2.1.1 is outdated at this point, please upgrade to v2.2.1
hi @francislavoie,
i have upgraded caddy to v2.2.1 and have tried updated caddy config after omiting ASCII armor.
           "certificates": {
               "load_pem": [
   					"@id":"local",
                       "key": "MHcCAQEEIMITGzUi9r3IAldcLRgTavTj/dWRokqt/msBupjZWg+OoAoGCCqGSM49AwEHoUQDQgAEf3nbqHqnVm[...]Lg==",
                       "certificate":"MIICgzCCAimgAwIBAgIUU63ZBpRAwDgYDVQQHEwdSZWxlaWdoMQ0wCwYDVQQKEwRFREpYMRQwEgYDVQQLEwtFbm[...]A0IABH=",
                       "tags": [
Still giving same error :
run: loading initial config: loading new config: loading tls app module: provision tls: loading certificates: PEM pair 0: tls: failed to find any PEM data in certificate input
Hmm okay. So next, I recommend trying it with the ASCII armor, and also with the \n newlines in the value. PEM typically has a \n every 64th character of the contents.
Yes, Worked this time with ASCII armor. version was the issue.
Thanks !
