1. Output of caddy version
v2.6.2
I’ve been using Caddy as the reverse proxy for a few internally-hosted services. Nothing special, just web front-ends.
Ubuntu sever 20.04 LTS
No docker. Just plain Ubuntu with Caddy installed.
None - happens automatically from however the automated installer handles the setup.
none
I don’t feel comfortable putting my domain names on a public forum, so have changed them in the below config.
##------------- Global Settings -------------##
#acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
email letsencrypt-caddy@example.com
##------------- Public External -------------##
#--- Uptime Monitoring ---#
ping.example.net {
respond 200 {
close
#--- OwnTracks Recorder ---#
location.example.net, location.dyndns.example.org {
reverse_proxy http://192.168.1.45:8083
basicauth * {
# create new password hashes with `caddy hash-password`
user1 ABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890
user2 ABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890
user3 ABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890
user4 ABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890
user5 ABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890
#--- Gotify ---#
push.example.net {
reverse_proxy 192.168.1.45:1680
#--- Nextcloud ---#
cloud.example.net {
reverse_proxy 192.168.1.45:1480
output file /var/lib/caddy/cloud.access.log {
roll_size 5mib
roll_keep 10
roll_keep_for 168h
# format single_field common_log
format console {
time_format wall
Permissions-Policy "autoplay=(self), camera=(), fullscreen=(self), geolocation=(), microphone=(), payment=()"
Strict-Transport-Security "max-age=31536000" # enable HSTS
#--- Jellyfin ---#
jellyfin.example.net {
reverse_proxy 192.168.1.34:8096
output file /var/lib/caddy/jellyfin.access.log {
roll_size 5mib
roll_keep 10
roll_keep_for 168h
Content-Security-Policy "upgrade-insecure-requests"
X-Frame-Options "DENY"
Server "No."
X-Xss-Protection "1; mode=block"
Up until this past month, the services have worked flawlessly and the certificates renewed without issue. However, this past month I’ve started to receive emails from the “Let’s Encrypt Expiry Bot” stating that my certificates will expire within the month - I know this in relation to my Caddy setup as they are sent to my specific Caddy email address.
When I check on the certificates I can see that they are not due to expire, but have been renewed via ZeroSSL ECC Domain Secure Site CA instead of the usual Let’s Encrypt channel.
I have no idea why this has changed.
No error, just email stating "Your certificate (or certificates) for the names listed below will expire in X days "
I was hoping to carry out a “test” renewal to see if I could see where the hiccup is, but I’ve not been able to find out how to do that.
None I can see.
