On any browser you get the issue of “ERR_SSL_PROTOCOL_ERROR” due to issues with certificates and letsencrypt.
(order=https://acme-v02.api.letsencrypt.org/acme/order/1801824347/281859241937) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
{"level":"error","ts":1719399128.9740498,"logger":"tls.obtain","msg":"will retry","error":"[media.jellyoctomedia.com] Obtain: [media.jellyoctomedia.com] solving challenges: presenting for challenge: could not determine zone for domain \"_acme-challenge.media.jellyoctomedia.com\": unexpected response code 'SERVFAIL' for _acme-challenge.media.jellyoctomedia.com. (order=https://acme-v02.api.letsencrypt.org/acme/order/1801824347/281859241937) (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":1.3247948,"max_duration":2592000}
Caddy 2.8.4
I installed it using the custom installer website. I did this so I could add on the cloudflare add on. I then run it as a service through nssma. System environment:
Windows 11
run --config ./caddyfile --adapter caddyfilePASTE OVER THIS, BETWEEN THE ``` LINES.
media.jellyoctomedia.com {
reverse_proxy 192.168.1.43:8096
dns cloudflare (API_TOKEN)
I’ve tried making my DNS resolver 1.1.1.1 but it also gives me the same error.
