Certificate Error in Browsers when using Automatic HTTPS with custom CA
Hello! I started working on a new Caddy setup today and ran into a strange problem regarding the automatic HTTPS feature.
I’m trying to set up Caddy as a reverse proxy to a service running in a local container. For HTTPS, I’d like Caddy to use a root CA certificate that is already deployed between my test machines, instead of generating a self-signed one.
I configured my CA public and private key in the global config, under the PKI section. It seems like Caddy successfully starts and generates an intermediate from the root CA I provided, as well as a certificate for the website itself. curl’ing to the website also seems to work fine.
However, both Chrome and Firefox refuse to proceed to the site, and show a warning page complaining about the site certificate being invalid.
The errors appear when trying to access the site both from a Linux and a Windows machine. I have verified that the root CA is trusted in both machines.
  • Chrome: net::ERR_CERT_INVALID, without much information otherwise.
  • Firefox: SEC_ERROR_CERT_SIGNATURE_ALGORITHM_DISABLED
    “The certificate is not trusted because it was signed using a signature algorithm that was disabled because that algorithm is not secure.”
Here is the certificate that Caddy generated for the site:
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            3c:2f:88:c3:66:5c:bb:e8:6d:56:2b:f5:c5:15:f5:70
        Signature Algorithm: ecdsa-with-SHA256
        Issuer: CN=Testnet Root CA - ECC Intermediate
        Validity
            Not Before: Mar 22 20:01:49 2025 GMT
            Not After : Mar 23 08:01:49 2025 GMT
        Subject:
        Subject Public Key Info:
            Public Key Algorithm: id-ecPublicKey
                Public-Key: (256 bit)
                pub:
                    04:cc:86:7b:66:ae:97:fb:82:e7:6f:9a:e8:95:a0:
                    af:63:b8:6c:3d:30:be:83:83:da:2a:08:40:86:0e:
                    a0:e5:79:38:1d:6b:8f:5f:9b:c4:87:ff:db:79:b7:
                    f5:02:be:d4:63:d6:4d:4c:ce:85:48:f0:64:c4:86:
                    d0:0d:48:74:5e
                ASN1 OID: prime256v1
                NIST CURVE: P-256
        X509v3 extensions:
            X509v3 Key Usage: critical
                Digital Signature
            X509v3 Extended Key Usage:
                TLS Web Server Authentication, TLS Web Client Authentication
            X509v3 Subject Key Identifier:
                59:01:AB:06:0F:AB:BA:99:51:F4:3E:F1:A4:59:F2:AD:8E:64:10:52
            X509v3 Authority Key Identifier:
                F2:44:97:2C:FE:AD:24:50:09:A2:B6:2F:B9:30:0B:B1:21:F4:38:A5
            X509v3 Subject Alternative Name: critical
                DNS:chat.opal
    Signature Value:
        30:46:02:21:00:c8:9d:39:c3:a9:52:d0:22:ac:20:d4:82:87:
        d2:76:a5:dc:9b:a5:e5:97:c2:52:c4:49:74:b9:ab:76:af:75:
        33:02:21:00:c1:62:d4:43:bf:30:9a:a7:35:74:f0:48:b2:80:
        07:a7:72:b2:12:d7:ec:f0:fb:76:0c:71:f2:fd:24:35:36:95
Caddy log:
Mar 22 22:01:49 opalium systemd[1]: Starting Caddy web server...
Mar 22 22:01:49 opalium caddy[98315]: {"level":"info","ts":1742673709.240114,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Mar 22 22:01:49 opalium caddy[98315]: {"level":"info","ts":1742673709.2406673,"msg":"adapted config to JSON","adapter":"caddyfile"}
Mar 22 22:01:49 opalium caddy[98315]: {"level":"info","ts":1742673709.240857,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0006c2780"}
Mar 22 22:01:49 opalium caddy[98315]: {"level":"info","ts":1742673709.2555566,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Mar 22 22:01:49 opalium caddy[98315]: {"level":"info","ts":1742673709.2555687,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Mar 22 22:01:49 opalium caddy[98315]: {"level":"debug","ts":1742673709.2555816,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["chat.opal"]},{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}],"logs":{"logger_names":{"chat.opal":["log0"]}}},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":":3000"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{},"logs":{"logger_names":{"chat.opal":["log0"]}}}}}}
Mar 22 22:01:49 opalium caddy[98315]: {"level":"info","ts":1742673709.2556894,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0006c2780"}
Mar 22 22:01:49 opalium caddy[98315]: Valid configuration
Mar 22 22:01:49 opalium caddy[98334]: caddy.HomeDir=/var/lib/caddy
Mar 22 22:01:49 opalium caddy[98334]: caddy.AppDataDir=/var/lib/caddy
Mar 22 22:01:49 opalium caddy[98334]: caddy.AppConfigDir=/etc/caddy
Mar 22 22:01:49 opalium caddy[98334]: caddy.ConfigAutosavePath=/var/lib/caddy/autosave.json
Mar 22 22:01:49 opalium caddy[98334]: caddy.Version=v2.9.1
Mar 22 22:01:49 opalium caddy[98334]: runtime.GOOS=linux
Mar 22 22:01:49 opalium caddy[98334]: runtime.GOARCH=amd64
Mar 22 22:01:49 opalium caddy[98334]: runtime.Compiler=gc
Mar 22 22:01:49 opalium caddy[98334]: runtime.NumCPU=16
Mar 22 22:01:49 opalium caddy[98334]: runtime.GOMAXPROCS=16
Mar 22 22:01:49 opalium caddy[98334]: runtime.Version=go1.24.1
Mar 22 22:01:49 opalium caddy[98334]: os.Getwd=/
Mar 22 22:01:49 opalium caddy[98334]: PATH=/usr/local/sbin:/usr/local/bin:/usr/bin
Mar 22 22:01:49 opalium caddy[98334]: XDG_DATA_DIRS=/var/lib/flatpak/exports/share:/usr/local/share/:/usr/share/
Mar 22 22:01:49 opalium caddy[98334]: NOTIFY_SOCKET=/run/systemd/notify
Mar 22 22:01:49 opalium caddy[98334]: USER=caddy
Mar 22 22:01:49 opalium caddy[98334]: LOGNAME=caddy
Mar 22 22:01:49 opalium caddy[98334]: HOME=/var/lib/caddy
Mar 22 22:01:49 opalium caddy[98334]: INVOCATION_ID=ac840e5959d0452aabac267754099487
Mar 22 22:01:49 opalium caddy[98334]: JOURNAL_STREAM=9:506356
Mar 22 22:01:49 opalium caddy[98334]: SYSTEMD_EXEC_PID=98334
Mar 22 22:01:49 opalium caddy[98334]: XDG_DATA_HOME=/var/lib
Mar 22 22:01:49 opalium caddy[98334]: XDG_CONFIG_HOME=/etc
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.31644,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3170245,"msg":"adapted config to JSON","adapter":"caddyfile"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3173041,"logger":"admin","msg":"admin endpoint started","address":"unix//run/caddy/admin.socket","enforce_origin":false,"origins":["","//127.0.0.1","//::1"]}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3183305,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.318339,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"debug","ts":1742673709.318351,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["chat.opal"]},{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}],"logs":{"logger_names":{"chat.opal":["log0"]}}},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":":3000"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{},"logs":{"logger_names":{"chat.opal":["log0"]}}}}}}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3183756,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00076a100"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3184392,"logger":"pki.ca.testnet","msg":"root certificate is already trusted by system","path":"/etc/pki/ca.crt"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"debug","ts":1742673709.3185081,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"warn","ts":1742673709.3185213,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"warn","ts":1742673709.3185236,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3185256,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"debug","ts":1742673709.3185408,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":false}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3185437,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3185713,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3188076,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.318822,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["chat.opal"]}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3188965,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/autosave.json"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.318922,"msg":"serving initial configuration"}
Mar 22 22:01:49 opalium systemd[1]: Started Caddy web server.
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.321358,"logger":"tls","msg":"cleaning storage unit","storage":"FileStorage:/var/lib/caddy"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3241239,"logger":"tls.obtain","msg":"acquiring lock","identifier":"chat.opal"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3268013,"logger":"tls","msg":"finished cleaning storage units"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3294415,"logger":"tls.obtain","msg":"lock acquired","identifier":"chat.opal"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3294735,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"chat.opal"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"debug","ts":1742673709.3294861,"logger":"events","msg":"event","name":"cert_obtaining","id":"e3f9a4da-6af9-4737-916a-c18d33a1e106","origin":"tls","data":{"identifier":"chat.opal"}}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"debug","ts":1742673709.3295605,"logger":"tls","msg":"created CSR","identifiers":["chat.opal"],"san_dns_names":["chat.opal"],"san_emails":[],"common_name":"","extra_extensions":0}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"debug","ts":1742673709.3297248,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"testnet"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"debug","ts":1742673709.3299193,"logger":"pki.ca.testnet","msg":"using intermediate signer","serial":"11662252775630462296731532533870731060","not_before":"2025-03-22 20:01:49 +0000 UTC","not_after":"2025-03-29 20:01:49 +0000 UTC"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3386323,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"chat.opal","issuer":"testnet"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"debug","ts":1742673709.3386652,"logger":"events","msg":"event","name":"cert_obtained","id":"c787152e-282a-42a3-942c-f091e8340570","origin":"tls","data":{"certificate_path":"certificates/testnet/chat.opal/chat.opal.crt","csr_pem":"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","identifier":"chat.opal","issuer":"testnet","metadata_path":"certificates/testnet/chat.opal/chat.opal.json","private_key_path":"certificates/testnet/chat.opal/chat.opal.key","renewal":false,"storage_path":"certificates/testnet/chat.opal"}}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"info","ts":1742673709.3386781,"logger":"tls.obtain","msg":"releasing lock","identifier":"chat.opal"}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"debug","ts":1742673709.3388553,"logger":"tls.cache","msg":"added certificate to cache","subjects":["chat.opal"],"expiration":1742716910,"managed":true,"issuer_key":"testnet","hash":"b2cadc04950191c96a4fc5b974e649e18cbe5cb0361f08f040f349b5ed7847ff","cache_size":1,"cache_capacity":10000}
Mar 22 22:01:49 opalium caddy[98334]: {"level":"debug","ts":1742673709.3388665,"logger":"events","msg":"event","name":"cached_managed_cert","id":"651f0f07-0325-43bb-933c-f28ed0e120a3","origin":"tls","data":{"sans":["chat.opal"]}}
Mar 22 22:04:55 opalium caddy[98334]: {"level":"debug","ts":1742673895.4976525,"logger":"events","msg":"event","name":"tls_get_certificate","id":"eedb5b67-577c-4d40-94f6-d659f5af6eff","origin":"tls","data":{"client_hello":{"CipherSuites":[19018,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"chat.opal","SupportedCurves":[23130,4588,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[64250,772,771],"RemoteAddr":{"IP":"10.10.10.10","Port":58944,"Zone":""},"LocalAddr":{"IP":"10.10.10.10","Port":443,"Zone":""}}}}
Mar 22 22:04:55 opalium caddy[98334]: {"level":"debug","ts":1742673895.4977386,"logger":"tls.handshake","msg":"choosing certificate","identifier":"chat.opal","num_choices":1}
Mar 22 22:04:55 opalium caddy[98334]: {"level":"debug","ts":1742673895.497744,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"chat.opal","subjects":["chat.opal"],"managed":true,"issuer_key":"testnet","hash":"b2cadc04950191c96a4fc5b974e649e18cbe5cb0361f08f040f349b5ed7847ff"}
Mar 22 22:04:55 opalium caddy[98334]: {"level":"debug","ts":1742673895.4977503,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.10.10.10","remote_port":"58944","subjects":["chat.opal"],"managed":true,"expiration":1742716910,"hash":"b2cadc04950191c96a4fc5b974e649e18cbe5cb0361f08f040f349b5ed7847ff"}
Mar 22 22:04:55 opalium caddy[98334]: {"level":"debug","ts":1742673895.4990656,"logger":"http.stdlib","msg":"http: TLS handshake error from 10.10.10.10:58944: remote error: tls: unknown certificate"}
v2.9.1
EndeavourOS (Arch Linux) 6.13.7 (Zen Kernel)
systemd 257 (257.4-1-arch)
I’m running Caddy as a systemd service, per the default configuration of the package.
sudo systemctl (re)start caddy
Just the default one that came with the package:
# caddy.service
Description=Caddy web server
After=network-online.target
Wants=network-online.target
StartLimitIntervalSec=14400
StartLimitBurst=10
Type=notify
Environment=XDG_DATA_HOME=/var/lib
Environment=XDG_CONFIG_HOME=/etc
ExecStartPre=/usr/bin/caddy validate --config /etc/caddy/Caddyfile
ExecStopPost=/usr/bin/rm -f /run/caddy/admin.socket
# Do not allow the process to be restarted in a tight loop. If the
# process fails to start, something critical needs to be fixed.
Restart=on-abnormal
# Use graceful shutdown with a reasonable timeout
# Hardening options
DevicePolicy=closed
LockPersonality=true
MemoryAccounting=true
MemoryDenyWriteExecute=true
NoNewPrivileges=true
PrivateDevices=true
ProcSubset=pid
ProtectClock=true
ProtectControlGroups=true
ProtectHome=true
ProtectHostname=true
ProtectKernelLogs=true
ProtectKernelModules=true
ProtectKernelTunables=true
ProtectProc=invisible
ProtectSystem=strict
RemoveIPC=true
ReadWritePaths=/var/lib/caddy /var/log/caddy /run/caddy
RestrictNamespaces=true
RestrictRealtime=true
RestrictSUIDSGID=true
# Global configuration
	# Restrict the admin interface to a local unix file socket whose directory
	# is restricted to caddy:caddy. By default the TCP socket allows arbitrary
	# modification for any process and user that has access to the local
	# interface. If admin over TCP is turned on one should make sure
	# implications are well understood.
	admin "unix//run/caddy/admin.socket"
	pki {
		ca testnet {
			name "Testnet Root CA"
			root {
				format pem_file
				cert /etc/pki/ca.crt
				key /etc/pki/private/ca.key
chat.opal {
		issuer internal {
			ca testnet
		output file /var/log/caddy/chat.opal/access.log {
			mode 640
	reverse_proxy :3000
I’ve followed this and this pages in the docs to set up the config.
I’m honestly kinda stumped by this one, so your help is very much appreciated.
Cheers!
-Opalium
I believe Chrome is using a system wide trusted CA store, while Firefox has its own trust store. Make sure your CA is installed in the Firefox’s trusted CA store.
When the format is pem_file, then the cert is expected to be in .pem format, not .crt.
Will it work in .crt if it is encoded in PEM starting with -----BEGIN CERTIFICATE----- and ending in -----END CERTIFICATE-----? No idea, but I’d try getting it in a .pem file format and see if that corrects it.
I verified that the root CA is trusted in both browsers, on both machines. The problem is still happening unfortunately. From the errors, I don’t think it has to do with trust, but rather with the certificate itself?
Indeed, they are both already in PEM format. I tried to set the file type to .pem as well, but nothing changed.
Thank you for the ideas.
Any other suggestions?
This says it’s complaining about the signature algorithm used for the certificate
This is what the certificate uses:
You’re gonna have to check why Firefox rejects this algorithm. As far as I know, it’s modern enough. Maybe your system is configured with specific paramters?
Hi again. I managed to solve the problem eventually - turns out the issue was with the root CA I used. It was issued with a signing algorithm that browsers don’t seem to like, and this broke the rest of the trust chain.
Thanks again for all the suggestions people. Cheers.
